New Matrice 300 RTK Firmware Released (11/30/2021)
2285 14 2021-11-30
DJI Support
Flight distance : 2408 ft
Overview:
Released Date: 2021.11.30
Aircraft Firmware: v03.00.01.01
Remote Controller Firmware: v03.01.00.00
Pilot App Android: V3.0.1.9(M300)
D-RTK 2 Mobile Station for Matrice: v03.00.00.16 (D-RTK 2 Mobile Station: v02.02.0505)
Intelligent Battery Station: v03.00.01.01
Intelligent Fight Battery: v01.02.05.31
Zenmuse H20/H20T: v03.00.01.02
Zenmuse P1: v03.00.01.04
Zenmuse L1: v03.00.02.00
Zenmuse Z30: v01.00.07.10
Zenmuse XT2: v01.00.03.50
Zenmuse XT S: v01.00.00.09
DJI X-Port: v01.03.02.00
DJI Skyport: v01.04.00.00
DJI Skyport V2: v01.03.02.00
DJI Assistant 2 (Enterprise Series): v2.1.2
Firmware Upgrade Method:
Aircraft/ Remote Controller: DJI Assistant 2 / App
Zenmuse H20 / H20T: microSD card / DJI Assistant 2 / App
D-RTK 2 Mobile Station: DJI Assistant 2
The built-in DJI Pilot app: will be updated with the Remote Controller firmware
Intelligent Battery Station: App (Connect the Battery Station to the remote controller and update it on the HMS page in the DJI Pilot app.)
What's new?
  • Fixed issue: customized RTK network connection failed in some countries.
  • Fixed issue: Pin Point was displayed at bottom of remote controller screen when takeoff altitude was negative.
  • Fixed issue: relative height was incorrectly displayed by default instead of altitude when aircraft entered Live Mission Recording in RTK mode.
  • Fixed issue: abnormal metadata appeared in live view.
Notes
  • Users who use Custom Network RTK must update the aircraft firmware to v01.00.02.14 or later. Otherwise, the aircraft will work abnormally.
  • The aircraft cannot revert to firmware version 01.00.02.11 or earlier once the firmware is updated.
  • Make sure that the aircraft, remote controller, battery, D-RTK 2 mobile station (if used), payload (if used) are updated to the latest firmware version.
  • Download the latest firmware from official website to microSD card to update the ZenmuseZ30, XT S, XT2, P1 or H20/H20T.
  • It is required to use the DJI Pilot app built-in the remote controller, or download the app of V2.2.1.7 or later.
  • DJI Pilot app must be updated to v.3.0.1.4 to use Offline Update.
2021-11-30
Frontliner 2020
Philippines
thank you for the info...
2021-11-30
Montfrooij
Flight distance : 2560453 ft
Thanks for the update!
2021-12-1
djiuser_7I97KTt0iDNt
Flight distance : 13898 ft
An hour ago I downloaded the recent dj fly app update and firmware on my air 2s for my s21 ultra. No my video resolution settings are completely gone. No option to select anything. Set at 1080p on auto and pro mode. Could usually select 2k 4k and 5.1k on the settings.
2021-12-2
djiuser_9A18J0DVDdEI
Argentina
Thanks for the update. Now height limitation is 1500 meters? as i need to for high altitude
2021-12-9
DP Timo
Flight distance : 183668 ft
djiuser_9A18J0DVDdEI Posted at 12-9 13:25
Height limitation 1500? In all countries?
2021-12-11
Arnor
Flight distance : 2660509 ft
Belgium
djiuser_7I97KTt0iDNt Posted at 12-2 18:07
Just wondering how this could be related to an update on M300? :-)
2021-12-16
Dong ZeYuan
Flight distance : 57060 ft
Thanks for sharing.
2021-12-21
EduardAbramov
Flight distance : 16401998 ft
Russia
Hello everyone! I have a problem. Yesterday I took off normally and after three minutes the connection was interrupted, the drone successfully returned and landed, the connection was never restored. I tried to reboot, it didn’t help, then I tried to carry out the pairing procedure, it didn’t help either. Today I updated the drone to a new firmware, and as a result, DJI Assistant 2 cannot load the list of software, just as when turned on, I start blinking 2 two indicators alternately on the battery, and the motors do not play the launch melody. What thoughts? What could be the problem?
2021-12-27
jmgl0003
Hi
I have a problem with the update firmware for the Zenmuse L1. The log is :
[00076415]========== Upgrade: 2022.02.21 21:21:45. boot(0775)============
[00076504]Current version: loader[00.01.1822] firmware[00.01.1802].
[00076592]Firmware [A:\H1CamFw.bin 0x9338489ccc2346c79ee5deb31edc6c2c] detected, card sn [0xb3640ed1].
[00076681][01 00] Firmware upgrade start...
[00076768][01 00] Firmware upgrade tracecode 0x00010000
[00076859][01 00] Firmware upgrade tracecode 0x00020000
[00081482][01 00] Firmware upgrade tracecode 0x00030000
[00081571][01 00] Firmware upgrade tracecode 0x00040000
[00090530][01 00] Firmware upgrade tracecode 0x00050000
[00090619][01 00] Firmware upgrade tracecode 0x00060000
[00090707][01 00] Firmware upgrade tracecode 0x00070000
[00116697][01 00] Camera firmware programed successfully.
[00008154][01 00]Firmware upgrade failed at resume stage.
[00008240]Done.
I have updated the aircraft, the controller and the pilot app, but I can't update the zenmuse. Please help me, I don't know what's happening.
Thank you
2022-2-21
Arnor
Belgium
jmgl0003 Posted at 2-21 12:57
Hi
Which L1 FW are you installing?
https://terra-1-g.djicdn.com/851 ... FW_V03.00.02.00.bin
Are you installing via Windows Enterprise App? Or via Controller? Windows is most of the time more stable
2022-2-22
jmgl0003
Arnor Posted at 2-22 08:12
https://terra-1-g.djicdn.com/851d20f7b9f64838a34cd02351370894/zenmuse%E5%9B%BA%E4%BB%B6/ZENMUSE_L1_series_FW_V03.00.02.00.bin
I have tried via sd card and app:
Firmware Upgrade Method: DJI L1 - SD card / Update All in App
2022-2-22
jmgl0003
The file is the same. The size and name is the same as the one I tried to install.
2022-2-22
Arnor
Belgium
Contact your DJI Enterprise reseller?
Did you try another SD Card? The previous firmware version? I wish you the best, it sucks when those expensive"thing" won't cooperate.
2022-2-23
jmgl0003
My L1 can't update it gives an error at 39%. What can I do?
2022-3-4
