Buzzyone
Flight distance : 4647913 ft
I have used my standard Mini 2 controller with my M3 Cine.
To connect the standard controller you will
Need to have internet connection in order to update the firmware.
After connecting your mobile device to the controller, start the Fly App and then it gives you the option to start a connection guide, select Mavic 3, the Fly App will then update the firmware in the RC.
Once that is done power up the Mavic 3 and once it’s ready, in the Fly App select linking in the App (three dots, control, scroll to the bottom select connect to aircraft) on the drone press and hold the button on the battery for 4 seconds until the drone beeps, after a few seconds it will connect to controller.
You will also need to Bind the controller to the drone to be covered by the DJI fly away cover. Follow instructions on screen.
Currently you cannot connect the RC Pro to different drones. It will only work with Mavic 3 or Mavic Air 2S depending on which it was supplied with, for now! |
