JJB*
Flight distance : 12260774 ft
Hi,
Interesting case this high change in barometric values in this flight, agree ; out of the normal at first thought.
But what i notice in your flight that you had changed your max height twice in this flight.
2m16s > FlyApp max height change [ 1640 ft ]
11m59 > FlyApp max height change [ 492 ft ]
Max Height setting changes should not have effect on the baro value.....but who knows....
Just for trouble shooting and fault isolating : can you fly again this route and change the max height in the app before take-off?
Another test is to start a flight, climb to 400 feet, and down to start position ; see the baro height indication. this to rule out baro changes over distance.Baro pressure can vary over distance, and in this flight the max distance out = 15000 feet!.
1 mbar equals 30 feet height change.
cheers
JJB
