New D-RTK 2 High Precision GNSS Mobile Station Firmware Released ...
2022 9 2021-12-8
DJI Support
Flight distance : 2408 ft
Overview
Date: 2021.12.08
Firmware: v03.01.0000
What’s New?
Removed restrictions for using mobile station in certain regions or countries according to country code.
Note:
The firmware cannot revert to an earlier version after this update.
2021-12-8
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2021-12-8
patiam
Flight distance : 1118740 ft
Is that the only change? If so, I'll pass.
2021-12-15
DCC Drone
We still can't input custom coordinate systems?
2021-12-18
Dong ZeYuan
Flight distance : 57060 ft
Thanks for sharing.
2021-12-21
DJI4Survey
Flight distance : 6484478 ft
Need to be able to toggle off the 15m (used to be 50m) coordinate entry restriction.  A lot of our projects have custom height datums that we have to find work arounds for.
2021-12-21
Raw_B
Flight distance : 1494190 ft
way to be more inclusive!
2021-12-27
djiuser_GvIS0lLOrOXM
M2EA, how about details to connect to NTRIP in the San Juan Mountains SW Colorado. Need to speak Chinese to understand the process without falling into a rabbit hole. Other question: with only single puck, what are the chances of even working. Thanks,
Randy
2022-1-7
Gernot Baier
Flight distance : 156598 ft
Austria
DCC Drone Posted at 2021-12-18 07:31
hopefully they add a feature to add the height of the Rod first -  but you are right for professional use the system in it´s current state is just dreadfull - you can make it work with a lot of workarounds though
2022-2-8
Gernot Baier
Austria
DJI4Survey Posted at 2021-12-21 21:49
you can do this in the postprocessing though (at least in pix4D you can use User-defined coordinate systems and shifts)
2022-2-8
