New DJI Force Pro Firmware Released (12/8/2021)
2541 2 2021-12-8
DJI Support
Flight distance : 2408 ft
Overview
Date : 2021.12.08
DJI Force Pro Firmware : v1.5.0.40
DJI Pro Wireless Receiver Firmware: v1.2.0.10
DJI Pro Assistant for Ronin (PC) : v2.0.2
DJI Pro Assistant for Ronin (Mac): v2.0.2
What’s New?
  • Added movements control, recenter control, and max speed settings for pan, tilt, and roll axes of Ronin 4D (other features are not supported currently).
Notes:
  • To control Ronin 4D, go to Settings of DJI Force Pro and select Custom, Switch, and then Ronin 4D.
  • To control Ronin 4D, connect the DC IN port of the DJI Remote Monitor Expansion Plate and the DC OUT port of the DJI Force Pro using the DJI High-Bright Remote Monitor Controller Cable.
  • Update the firmware through DJI Pro Assistant for Ronin by connecting the USB-C port on DJI Force Pro to your computer. Do not disconnect the DJI Force Pro from the computer during update process.
  • Make sure to update both the gimbal and DJI Pro Wireless Receiver to the latest firmware. Otherwise, DJI Force Pro will not be able to control the gimbal. Restart the gimbal after the update is complete.
  • If the firmware update fails, restart the DJI Force Pro and reconnect the USB, and retry.
2021-12-8
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2021-12-8
Dong ZeYuan
Flight distance : 57060 ft
Thanks for sharing.
2021-12-21
