DAYTONA392
Flight distance : 131942 ft
djiuser_3uZkaI6cGNDr Posted at 12-10 07:35
I can not create a new topic so I am writing in this one. my drone does not turn on, the indication works and shows the battery charge, but the drone cannot be turned on If you're pressing the power button momentarily, that will only show you the battery indication with the battery in the Drone. You have to press it once momentarily, followed immediately by pressing and holding the power button. Then you will see a series of Lights underneath and hear it turn on. If it still doesn't work after that (assuming you have a charged battery installed) I would get ahold of DJI support because it's not functioning as it should. |
