DJI FLY APP 1.5.4 - WHATS NEW? iOS & ANDROID DJI MAVIC 3, MINI 2 ...
1526 7 2021-12-11
DAFlys
DJI FLY APP 1.5.4 - WHATS NEW? iOS & ANDROID DJI MAVIC 3, MINI 2 / MAVIC AIR 2S
2021-12-11
Montfrooij
Flight distance : 2560453 ft
Nice find!
2021-12-11
DAFlys
Cheers Peter.
2021-12-12
Montfrooij
You're welcome!
2021-12-12
djiuser_KPi2hv5uW4fI
Flight distance : 4764 ft
There are two other issues at least with Mini2.
1. Camera view sometimes frozen after take off. Mostly happened when some info pop up at the time of taking off, e.g. in restricted area, or RTH update, etc. When the view is frozen, histogram still alive so camera and transmission should be no problem, record on SD card confirms that.
2. Yaw setting do not update at power up of aircraft, meaning it takes some kind of default settings instead of what you set in the App. But if you toggle the mode switch say from Cine to normal then back to Cine, the drone can take the changes.
2021-12-13
DAFlys
djiuser_KPi2hv5uW4fI Posted at 12-13 06:51
Ive not had the freezing,  but the startup in cine/sport mode is known behaviour,  it always starts normal regardless of whats set on the controller,  Its done for safety I believe.
2021-12-13
GTS 350
For androids with OS 12 they forgot the feature where the app crashes instead of working.
2021-12-20
DAFlys
GTS 350 Posted at 12-20 12:45
Have you tried the new 1390 release,  lots have had success with that on Android 12
2021-12-20
