M2Z is no longer recognized by USB
379 8 2021-12-14
airwiss
Flight distance : 252300 ft
Russia
After flashing through the Assistant to the latest version, the Mavic 2 Zoom is no longer recognized by USB. Changed cables and computers. No results. The firmware process went fine without any hints of error. The copter flies and controls perfectly.
Who faced such a problem and how can you solve it on your own?
2021-12-14
Sean-bumble-bee
Flight distance : 15997 ft
can you state the version by number etc. please? Thanks
2021-12-14
Hi there, sorry that you're having this issue. May I ask if the upgrade process finish completely? Could you please reboot the drone and computer and try again for a test?
2021-12-15
airwiss
Russia
Sean-bumble-bee Posted at 12-14 22:48
01.00.0770
2021-12-15
airwiss
Russia
DJI Mindy Posted at 12-15 03:21
Of course, before writing on this forum, computers both rebooted and changed. I tried both windows and mac. Cables also changed, including certified ones from apple. The drone has turned off and on many times. The result is the same - the copter is not detected either by the assistant through which it was stitched, nor by any system utilities.
2021-12-15
Sean-bumble-bee
"01.00.0770" Thanks.
2021-12-15
FloridaNext
Flight distance : 62320 ft
airwiss Posted at 12-15 03:38
This sounds bad. Can you look closer into the USB jack of the drone with a flashlight? May be one or more pins are broken. They are not made to last forever ...
2021-12-15
Sorry to know about this. In this case, you may start a case through the link below and send it back for further diagnosis. http://www.dji.com/support
2021-12-17
GaryDoug
Flight distance : 1264639 ft
Could be time for a repair:
https://cloudcitydrones.com/products/mavic-air-2-usb-port-board
https://www.ebay.com/itm/303976162106
2021-12-17
