DJI Ronin SC Balancing
2165 3 2021-12-18
PraveenK
Hi,
I'm trying to balance dji ronin sc with sony a6400 and Tamron 17-70 f2.8 lens but failing every time. I saw some YouTube videos they balanced it very well. This is my first time using giumbal. Is there any weight I need to balance? Any suggestions please?
2021-12-18
Hi there, you can refer to the tutorial below to see if it helps.
2021-12-22
SparkMiniAirPocket1-2Fan
Flight distance : 61421 ft
Austria
DJI Mindy Posted at 2021-12-22 03:30
Hi there, you can refer to the tutorial below to see if it helps. https://www.youtube.com/watch?v=LDsucszkCp4&list=PL65kukZorPdPWNpoFicolA_lT8dD5MWMH&index=17
Hi DJI Mindy :-)
Is there any reason, that there's no Tamron Lenses in den compatible list? Is these lense TOO heavy?
2022-5-1
SparkMiniAirPocket1-2Fan Posted at 5-1 07:00
Hi DJI Mindy :-)
Although the said lens brand is not on the compatibility list, it does not mean it's not compatible. If it's able to mount the lens and balance it properly, it can also work normally with Ronin SC.
2022-5-6
