Nicodema
Flight distance : 90259 ft
OK, that's wierd. It would appear that the drone is applying some variant of warp stabilisation. At 0:16s the left gantry crane moves to the right, which in turn causes the ground seen through it to stretch to the left, as if it was a rubber sheet. Basically it's applying a perspective correction where there is not shift in viewpoint, so you get this erroneous warp.
I had no idea DJI were doing this, but it would explain why the rest of the timelapse is so steady. I mean the position holding is very good, and this would be just an optimisation, but one that is occasionally prone to slight errors like this. |
