Agsikapin
Philippines
IM USING VIVO V20 SMART PHONE AND FOR ANDROID SMART PHONE USER THERE YOU MAY ALSO TRY THIS IF YOU ENCOUNTERED SAME PROBLEM WITH MINE.
FOR SPORT MODE ISSUE.
latest apk for android is working but theres no sport mode?
Ans.
still have sport mode maybe it appears that it is now named (Follow Speed) but it is not indicated if its on or off. you only see it at the 3 dot setting and then if you click 2 times and hold the trigger the follow speed setting will appear fast and then if you release trigger it will return to slow setting.
FOR STATIC ISSUE IN VIDEO PLAYBACK.
Ans.
try to use almost all function of dji mimo. hyperlapse, timelapsed, photo and pano.and then back to video and try to record it. i try about 5 times record it static and then i try to take selfie video and then back to rear cam. to take a video and then when i playback the video. it is now not static.
Hopefully it may help to the other android smart phone user out there.
Thank You
