3 blades propeller
433 4 2021-12-26
Roberto Pirodda
I have seen some ads about 3 blades propeller. Worth it ? Does anyone have tried it ? They claim better performance, less noise and battery saving
2021-12-26
Labroides
Flight distance : 9991457 ft
Worth it ?
No
Lots have, but how many have continued using them?
If it was that simple, DJI's propulsion engineers would already supply them as standard equipment.
If they were so good, we'd all be using them.
2021-12-26
Roberto Pirodda
Thanks Labroides, i have saved some money  :-)
2021-12-26
DJI Stephen
Hello there Roberto Pirodda. Good day and thank you for reaching out. It would be best to use the original DJI propellers on your DJI Drones for reliability and compatibility purposes.  Just a reminder that DJI do not recommend you to use a 3rd party accessories specially 3rd party propellers on your DJI Drones. There is a  possibility that these propellers will work, however, since it's not tested by DJI we cannot guaranteed the reliability and the stability of the said accessory when in use and can void the warranty of your DJI Drone. Thank you.
2021-12-26
GaryDoug
Flight distance : 1264639 ft
The only advantage I could imagine is, if one broke the other two might better keep the drone in the air. But I doubt there is any evidence to prove it. Otherwise it is just more friction with the air.
In marine applications, the fewer the propellor blades, the faster the boat....except for low speed boats under heavy load. Then, the more the better up to about 5.
2021-12-26
