Charging Case double red light and not green light status
4382 10 2022-1-5
Explorick
I just got my new pocket 2 charging case, I put it to charge. ( I own the original pocket and pocket case) and now the charging port blinks twice red and there is not battery green status. I read on webpages to update the firmware, but I cannot find a place to add in how to do it. please advise
2022-1-5
DJI Stephen
Hello there Explorick. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please post a short sample video showing the said issue for us to be able to see and can give out the best solution for this issue. In addition I will post a chart where in you can find the DJI Pocket 2 Charging Case Status Indicator Descriptions. Thank you.
2022-1-5
ExplorickOne
DJI Stephen Posted at 1-5 21:10
[view_image]
I will like to add video, but I get this…
2022-1-6
ExplorickOne
Well, DJI repair service look at it and said, main board is bad - required to pay for parts () but made a call and send resent purchase receipt... more to come.
2022-1-13
HGDC84
Finland
Hopefully the warranty is still available, at least it should be if it was brand new. I hope you'll get it fixed without too many extra costs.
2022-1-14
ExplorickOne
HGDC84 Posted at 1-14 05:55
and it is, just check now. it will be taken care. Not mad, because I do love the case charging and you can  carry the plugs and the filter in it.
should be here soon.
2022-1-14
HGDC84
Finland
ExplorickOne Posted at 1-14 08:24
Glad it is covered by warranty. Hope you'll get it soon :-)
2022-1-15
ExplorickOne
HGDC84 Posted at 1-15 01:56
Thank you, and should be here soon
2022-1-17
ExplorickOne
I just got it last night, I put it to charge and it works, I had use the camera to charge it and it did.
2022-4-13
fans7258f4e2
Senegal
So is there a fix or should I just send my back as well. Mine was working fine.
Now it's doing the same exact thing you described
2023-8-26
DJI Paladin
Flight distance : 318 ft
fans7258f4e2 Posted at 8-26 16:47
Hi there. We're deeply sorry for this inconvenience. Kindly please try the following troubleshooting steps below and see if this rectifies the issue:
Troubleshooting Steps:
1. Please check whether the firmware of the DJI Pocket 2 is the latest version. If not, it is recommended to update the firmware and try linking again.
2. Please open and close the charging case again to check whether the indicator on the charging case lights up. If it does not light up or the indicator blinks red quickly three times and then goes out, it indicates that the charging case has insufficient power. Please charge the charging case.
3. After placing the DJI Pocket 2 in the charging case correctly, manually close the charging case and check whether the indicator is in breathing status. If it is, it means it has been charged normally.
4. Please make sure that there is no debris on the contacts of the DJI Pocket 2 and the charging case. You can wipe it clean with alcohol before installing and charging.
2023-9-8
