DJI Terra. How to share results?
11106 18 2022-1-6
Mark7841
Flight distance : 352792 ft
Has anyone figured out how to share 3d models and mapping projects with clients through Terra? I have Pix4d mapper and cloud but I'm unable to properly export to it.
2022-1-6
fansb06c8725
Flight distance : 3963068 ft
No doubt!  How do you share your results with clients so it is easy for them to view?  I like Terra but if you can’t share then it’s of no use.
2022-2-22
LV_Forestry
Flight distance : 4726654 ft
Latvia
You have to go to my documents/DJI/DJITerra/username/your project
All orthophotos, DSM... should be there.
2022-2-23
FlorianGhe
Romania
I for one cannot use the 3D model because it doesn't have coordinates.
2022-8-3
AWAS
Does anyone have an answer to this been trying to send a 3d model image to a client and can’t figure out how to view the data once I export it. It’s saving as json files and I need to be able to show clients who don’t have DJI terra
2023-2-15
djiuser_AEoitJfIxkeq
LV_Forestry Posted at 2022-2-23 09:54
Hi there, new DJI Terra user here. I can find this data but I don't know how to compile it to share with clients or move in a deliverable format. At the moment, I am only looking to share 2D orthomosaics and 3D models. How do I take these files and create something that can be shared and/or easily opened on computers without DJI Terra software?
2023-2-21
LV_Forestry
Latvia
djiuser_AEoitJfIxkeq Posted at 2-21 08:18
In your project folder you must find the format files required in Terra. If you asked for .LAS you will find a .LAS file, if you asked for a 3D file you should find OBJ...
But Terra is a big crap. Orient yourself rather towards Agisoft Metashape, PIX4D... it's up to you to try the evaluation versions and find which one suits you best.
2023-2-21
fans6a12706a
Flight distance : 144692 ft
Anyone found any real option for showing OBJ or B3DM files from DJI that doesn't require the end customer to buy Terra themselves?
Does @DJI actually have a viable plan for deliverables?
Or even merging the files to a single file. Many of the online viewer extensions have limits and having Terra chop up the model into 4 or 5 files is useless.
2023-2-28
fans6a12706a Posted at 2-28 01:04
One way is to upload the files to Cesium and share a link with your end customer. There are also free 3D model viewers online, but they aren't very refined.
2023-3-13
Johnnokomis
Flight distance : 13349895 ft
To share a 3D model use Sketchfab. It's free and easy. To share an Orthomosaic easily I'm still trying to find a way. I have a 24GB GeoTIFF that I can't even open to down scale it. Flighthub 2 can display maps across devices but I don't see a way to share those maps without giving someone your credentials. Not recommended.
2023-3-13
ShammyLevva
Johnnokomis Posted at 3-13 17:44
Within the folder structure that is saved when you create the large geotiff file there will be a bunch of folders with a 2 digit number these are the tile layers. A tile is a 256x256 file that can be stitched together to display the image.
If you load these files up to a web server by just copying them you can point any GIS software that can display tileserver data at them. Things like the free QGIS is easy to use, or you can create overlays in Google Earth using a conversion server like https://github.com/grst/geos
Basically your file server has the files in 3 steps the 2 digit number is the “zoom level” or z value, the next directory is the X layer and the that directory contains the files that have the name.png or .jpg as the y value.
You then just point your software at http(s)://yourservername.com/yourtiledirectory/{z}/{x}/{y}.png
The software then just asks the tileserver for the right tiles at the right zoom and stitches them together on the fly as the user pans around and zooms in and out.
So by a simple copy and paste from the map directory of terra once it’s created your 2d ortho to your web server then you can view your Ortho on any software that can view tileservers.
Hope this helps.
2023-5-22
wackel-dackel
Flight distance : 376529 ft
Norway
ShammyLevva Posted at 5-22 16:03
This is too complicated for a regular user.
I think that DJI Terra in general is outstanding (fast, precise, reliable, easy, good data handling and export), just missing an online view tool for all projects to easy share the results and models with clients and other people. (This is a very important part of the software)
Ideal would be a solution in browser without any download/installing procedure. In the moment that becomes part of the software it will be unbeatable.
WebODM for example has such a solution in the package now, this is why we use it until Terra will have a online viewer.
2023-6-23
BaddogTwo
Flight distance : 2783189 ft
I found them after creating this directory structure.  Then setting Terra to use this as the Cache folder, then the software moved all my projects and files to this new directory Everything was there
E:\DJI\Terra Cache\
2023-6-23
Pysiak
Poland
Hi.
The free account at https://cesium.com/ has a capacity of 5 GB, so you can upload quite big project to share.
But I have another question: do you know any program/software that I could use to present projects offline? I have DJI Terra installed on a powerful PC, but I would like to show potential clients my projects during the presentation offline from my laptop.
2023-6-27
Edmondm
Flight distance : 8449826 ft
wackel-dackel Posted at 6-23 01:13
I agree with you and feel the same. I wish they had a service that can make it easy for us.
2023-8-22
Edmondm
John will you be willing to consult with me and teach me how to do this? Of course I can compensate you for your time. What you said is a bit too technical for me. I also have produced a 3D model via DJI Terra and I am trying to share with with my customer who wants this on their website.
2023-8-22
ShammyLevva4
Edmondm Posted at 8-22 14:05
My name is Alexander not John. I'd be happy to show you how we have done this for my company. It sounds complicated but once you deploy it to a website once it's trivial to simply give the client a URL and they can browse around and zoom in on the images. With the Zenmuse P1 and RTK M300 we have got images that are sub cm per pixel so are super detailed. I'm happy to share my knowledge on how we achieved this.
All you need is a webserver to upload the images that DJI terra already creates and a couple of lines of javascript on a webpage to serve them up. People have written presentation libraries that take care of the reset.
Edit: to date I've not worked out how to display 3d models but hope to have the time over the Xmas new year period to work it out.
2023-12-7
nazar404.yahoo
Flight distance : 394291 ft
ShammyLevva4 Posted at 2023-12-7 15:10
I am also looking for help with Dji Terra in sending the files B3dm or ply formats to a 3d viewer instead of terra it self ....
Dji can use some help on this topic
thank you
1-28 09:42
Kiko977
Flight distance : 5407730 ft
Tanzania
Hi all,
we had the same problem and we found a solution with Nira App.
It's a paid service, but works fine for both 3D and Orthos.
https://wti360.nira.app/a/b-YljbdbRgeJahtMAmG_WA/1
4-1 01:18
