JJB*
Flight distance : 10999196 ft
marc70 Posted at 1-7 09:31
Yes, was (first time) looking at log, and lots of irregularities going on there. Batteries just out of 1 year warranty. Figures.
Thanks for looking, let me know what you think: should I send it in, try again same/different battery?
Hi,
Had a better look, see if i could find some data connections between all values....
First your battery temperature, at start 20 degree Centigrade, last value 40.
But flying in -22 ; craft and motors getting real cold ofcourse....
Just before the RTH down input but your MINI2 started to climb, well indications of baro height values hows that. BUT vertical speed value a minus value!Normal behaviour is : RC stick down, craft height decreases and vert speed shows a minus value. (this minus value within specs as in the manual)
In RTH multiple RC down inputs, height increases and vertical speed shows large numbers down!! (out of my chart y-axis)
Rate of descend up to 42 m/s ! wich ofcourse is incorrect, this belongs to a brick falling down....
I have seen this before in few flights, but not in very cold temp flights though. A warrant case that was, but as you flew your MINI2 in minus -22....
With conflicting data values going beyond a certain threshold drone goes into ATTI mode.
This must be the reason for going into ATTI, as the GPS data isn`t used anymore by the drones FC/IMU ; thus into ATTI.
Amazing to see that ATTI changes into Normal mode again (see chart at Record # 5300), and your MINI2 gets normal values for descend,
craft is loosing height on down stick, batt volts normal and not fluctuating, same for amps.
Only at record 6482 a high rate of descend in the log, this for short moment. This with a batt voltage drop at the same time.
Lowest batt cell 3.28 volts, wich is not below the critical value of 3 volts.
Would be intersting to see your next flight in 'normal' temperatures with this battery, wich imo is a oke battery.
cheers
JJB
