Geo_Drone
Flight distance : 2676129 ft
Romania
Depends on your screen refresh rate, but probably not as you "see" on screen what the sensor sees but with lower res. So you should see if the propeller shadow is gone.
To answer to another question here:
Each image in video have a SS and FPS. The FPS is how many frames are taken over a second, the SS is how many times the shutter open and close in front of sensor (mechanically or electronically, no matter).
Now for logical part for beginners:
- The propellers have a high speed, creating a shadow each time the propeller cut the light that goes to sensor...
- Do you see with naked eye this directly? No...why? Because your eye is "blending" the image...how to do this also with the "electronic eye" of a drone? Easy:
* Lower the FPS to 25 - will take each second 25 frames, instead of 30-60-...., meaning that will "blend more" each second
* Lower your SS to 1/50 - as for 180 degree rule, but also because your shutter being more slow, will remain open long enough to blend the light...is like when you make pictures with your camera at night, more you keep the SS, more light is recorded and more blended is the image.
So...in order to minimize or even eliminate this shadows from props, you need to go lower with SS and FPS. Of course, in order to keep the same light and not to have an over-exposure, you need a ND Filter...This is why all says "Put a ND Filter"...not because your ND filter is magic and take the propeller shadow away, but because your camera is lowering the SS and "blends" the image more.
Cheers. |
