dunfr
Flight distance : 779413 ft
Hi
I am new to Action 2. Start with both modules connected - video Files go into a 100Media Folder - it starts raining, detach Power Module (not waterproof) internal memory files go into 101Media Folder. First video clips on sd card, and then internal memory, BUT always start file Index from 0001 - consequently now have same file names as 100Media Folder. Is there a way to select Continuous File Index Mode?
At the moment I am having to batch rename and re number each folders files.
I have exactly the same lack of Continuous File Index Mode with my Pocket 2. At least only one sd card! Trouble is the files also have exactly the same file names as Action 2. Always start from DJI_0001.***
So use Action 2 and Pocket 2 you can have 3 sets of different video clips with the same filenames. Just to add to the fun the timestamps on the internal Memory are approx 2 (1:55) hours later than actual time....
There is no ability to rename files in the Mimo app either.
Subsequently, if you try and assemble video with multiple clips in MiMo editor - crash. Similarly try and save multiple camera videos to iPhone photos - you lose half of the images (probably file name issue?).
