Control stick not central
1070 5 2022-1-10
BigTunaUK
Hey, hoping someone could help. Recently bought DJI mini 2. Every time i go to use i have go Calibrate the RC. Is this normal? I also spmetimes get an error on takeoff saying left stick isnt central. When i calibrate it sometimes shows that the stick is 10-15% down and changes 1%. Is this faulty and should o exchange.
Thanks
2022-1-10
yogi053
Flight distance : 26104915 ft
If after calibrating RC and it requests calibration again after powering down and then up, I would exchange kit at point of purchase if possible. Otherwise email Dji support and raise a ticket.
2022-1-10
DowntownRDB
Flight distance : 1722 ft
Yeah, that's not normal behavior.  You may received a faulty controller.  Probably best to contact DJI Support for assistance.
2022-1-10
GaryDoug
Flight distance : 1264639 ft
Sounds like an intermittent problem, the worst kind to fix. I would put a written explanation in the box detailing the problem when you return it.
2022-1-10
DJI Stephen
Hello there BigTunaUK. I am sorry for the trouble this has caused and thank you for reaching out. Since you have done some troubleshooting steps to fix the said issue of your DJI Mini 2 remote controller. I would recommend for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do there best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2022-1-10
Nata
hello. I have a similar issue.
my DJI RC calibration : not reaching 100% on the right joystick. (I have the dji mini pro 3)
First it was going "up" to 40% without me touching the joystick. left and right would remain on 0% even when pushing the joystick to the max.
I then downloaded the app "DJI assistance 2" and did a frimware refresh. re tryed the calibration.
now the left and right go to 100% normally. but the up and down remain in 0%
it seems therefor more a frimware/calibration issue than a physical issue.
any advice?
thanks
2023-4-10
