Sakari Kaulaote
Flight distance : 34941 ft
Sweden
Where can i find a motor or a part number for the motor? I can only find the whole arm assembly for sale.
Reason for that is, today front left motor failed to start at the first try. Second try it started.
After a short hover test it felt stiff. The motor is hard to rotate but it loosens up when i twist it manually.
I suspect the bearing is failing.
