DJI Stephen
Hello there marfuka. I am sorry for the trouble this has caused and thank you for reaching out. The Advanced Pilot Assistance Systems 4.0 (APAS 4.0) feature is available in Normal mode. When APAS is enabled, the aircraft continues to respond to user commands and plans its path according to both control stick inputs and the flight environment. APAS makes it easier to avoid obstacles, obtain smoother footage, and gives a better flying experience. Keep moving the pitch stick forward or backward. The aircraft will avoid the obstacles by flying above, below, or to the left or right of the obstacle. The aircraft will also respond to other control sticks movements simultaneously. When APAS is enabled, the aircraft can be brought to a stop by pressing the Flight Pause button on the remote controller or tapping Stop on the screen in DJI Fly. The aircraft hovers for three seconds and awaits further pilot commands. To enable APAS, open DJI Fly, enter System Settings>Safety, and enable APAS.
APAS is disabled when using Intelligent Flight modes and recording at high resolution such as 2.7K 48/50/60 fps, 1080p 48/50/60/120/240 fps, and 4K 48/50/60 fps.
APAS is only available when flying forward and backward. If the aircraft flies left or right, APAS is disabled.
Make sure you use APAS when the Forward and Backward Vision Systems are available. Be sure there are no people, animals, objects with small surface areas (e.g., tree branches), or transparent objects (e.g., glass or water) along the desired flight path.
Make sure you use APAS when the Downward Vision System is available or the GPS signal is strong. APAS may not function properly when the aircraft is flying over water or snow-covered area.
Be extra cautious when flying in extremely dark (<300 lux) or bright (>10,000 lux) environments. Pay attention to DJI Fly and ensure the aircraft is working in APAS mode normally.
Pay attention to DJI Fly and make sure the said DJI Drone is working normally in APAS Mode.
APAS may not function properly when the said DJI Drone is flying near flight limits or in a GEO Zone.
Thank you. |
