New Air2s Compass Calibration Keeps Failing
3717 11 2022-1-14
C5Drones
Flight distance : 256532 ft
Brand new Air2s out of the box.  Wanted to calibrate IMU and compass before first flight.  IMU calibrated no problem.  Cannot calibrate compass. Have tried multiple times in different places and always get failure message.  It flies fine. GPS is fine.  But I want to make sure I'm able to calibrate out of the box and when needed.  Saw on Youtube someone demagnatized the drone and was then able to calibrate compass. He said this can happen on all drones.  Before I take that step wanted to check here to see if anyone had guidance.  Thanks.
2022-1-14
Ex Machina
Flight distance : 1806362 ft
Make sure you have no metal on you and you are away from any metal while calibrating -- this includes watches, keys, etc. on your person, and ground locations where there might be steel reinforcement, like cement pads, or near fences.
If the drone flies well and orients properly it is unlikely to need calibration. In my experience you very rarely need to calibrate the compass. Hope this helps.
2022-1-14
C5Drones
Ex Machina Posted at 1-14 13:12
thanks. i did have keys in my pocket and my money clip has a magnet on it.. that could be it.  although i was able to calibrate the mini 2 with those in my pocket no problem.
2022-1-14
Labroides
Flight distance : 9991457 ft
First up, there is no need at all to calibrate anything before flying.
DJI have never suggestet that in their manuals.
It's a myth that has grown in this forum.
Usually a compass that won't calibrate is broken or disconnected.
But if yours is flying properly, the compass is properly calibrated.
You couldn't fly or hover without the compass being properly calibrated.
The only time you would need to calibrate the compass is if you add or remove accessories or rebuild the drone.
It's not something you need to do in normal circumstances.
And having keys, jewellery etc in your packet won't have any effect on compass calibration as they aren't magnetic.
Unless the money clip magnet is quite powerful, it probably wouldn't have much effect in your pocket.
Wearing a watch with a magnetic clasp, might.
2022-1-14
C5Drones
Labroides Posted at 1-14 13:48
thanks for the insight. yes it flies fine so the compass is working.. but its still concerning that I cannot calibrate it. this function should work without a hitch.
2022-1-14
GaryDoug
Flight distance : 1264639 ft
Where are you? It may be due to your location (Minnesota?). Are there any known magnetic/compass issues there, like high deposits of iron in the ground? Maybe try to calibrate again higher up.
Nevermind. I see that you are probably in New Jersey.
2022-1-14
DJI Paladin
Flight distance : 318 ft
Hi there, C5. Thank you for reaching out and we're sorry for the trouble. Please note that you need to perform the said calibration in an area wherein there is no magnetic interference also it is recommended to perform these steps in an open area without any metals around it to avoid issues. In addition, there is no need to perform the compass calibration if there are no issues or errors on the app as long as the status is normal without any errors, you are good to go. Hope this helps. Thank you for your valued support and happy flying!
2022-1-15
C5Drones
DJI Paladin Posted at 1-15 00:44
thanks for the info.
2022-1-15
hallmark007
Flight distance : 10017858 ft
If your compass is working you cannot make it better by calibrating, so out of the box calibration is not needed.
However you should still be able to calibrate. Are you doing it correctly, can you explain or post a video showing just exactly how you are doing it.
2022-1-16
DJI Paladin
C5Drones Posted at 1-15 08:38
You are most welcome. Have a wonderful day ahead and fly safe!
2022-1-17
djiuser_DKLShhEcfuVf
Kenya
Hello there my dji air 2s has this problem some one to help on how to  fix it
2023-8-1
DJI Tony
djiuser_DKLShhEcfuVf Posted at 8-1 09:36
Hi there. Sorry for the trouble you're experiencing. Have you already tried doing the IMU, Compass, and gimbal calibration? If you experienced a crash or collision we suggest sending the drone for repair. Don't hesitate to reply so I can assist you further. Have a great day ahead.
2023-8-2
