iPad Mini 6 and Phantom 4 Pro do not connect.ios15.1&ios15.2
1414 3 2022-1-16
PYM
Flight distance : 689888 ft
Japan
iPad Mini 6 and Phantom 4 Pro are not connected. ios15.1.&ios15.2.
It doesn't charge and doesn't seem to recognize the aircraft. No video is connected either. Does anyone have a solution?
Please help someone...
2022-1-16
DJI Stephen
Hello there PYM. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try using a different recommended mobile device to see if the said issue will persist. Upon checking the said mobile device ( iPad Mini 6 ) that your are trying to use on your DJI Phantom 4 Pro and on the DJI Go 4 application. I am sorry to say that the said mobile device is not recommended for the said DJI drone and on the said DJI application. We would suggest using a recommended mobile device for the DJI Go 4  application for compatibility and reliability purposes. There is a possibility that the iPad Mini 6 will be able to work on the DJI Go 4 application. But however, since it's not yet optimized with the said application and for the said DJI Drone we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Go 4 application while using it on your DJI drone. For reference I will post a DJI link  where in you can find the recommended mobile device for the DJI Go 4 application ( https://www.dji.com/downloads/djiapp/dji-go-4 ) . Thank you.
2022-1-16
PYM
Japan
DJI Stephen Posted at 1-16 18:47
thank you for your reply.
It was possible to fly with iPhone11ProMax (ios15.0.2).
For reference, we will tell you the version in which the problem is occurring.
Please verify.
▼ Phantom4 Pro v1
Aircraft: Version 01.05.0600
Transmitter: version 01.04.01.00
▼ App
Version 4.3.46
▼ iPad mini 6
ios15.1.0
ios15.2.1
2022-1-18
Bartłomiej
Flight distance : 6562 ft
Poland
DJI has been trying to fix the USB-C issue since 11.2021 r.
The iPad mini 6 was presented on 9.2021 r.
The last Phantom 4 Pro V1 / Advanced firmware update is from 2020 r.
Now we have 2023 r.
For me, this is DJI's clear answer to user needs.
2023-4-20
