New DJI RC Pro Firmware Released (1/24/2022)
12Next >
7901 55 2022-1-23
DJI Support
Flight distance : 2408 ft
Overview:
  • Release Date: 2022.01.24
  • Remote Controller Firmware: v03.01.0500
  • DJI Fly App: v1.5.8
What’s New?
  • Added support to output clean HDMI footage.
  • Added support to cache video and download original video to an external SD card.
  • Added support to use with DJI Air 2S.
  • Fixed some minor bugs.
Notes:
  • This version contains important updates. It is recommended to update the remote controller.
  • If the update fails, restart DJI RC Pro, and use DJI Fly or DJI Assistant 2 (Consumer Drones Series) to retry.
2022-1-23
KlooGee
Flight distance : 16783757 ft
Is there an option to change the right side dial and/or the 5D joystick to be able to directly control some of the exposure elements like aperture, ISO, or shutter speed?
If not, these are absolutely required to be able to adjust your exposure like a "Pro" would!  Please add if not already there.
2022-1-23
jonroemer
Flight distance : 1477598 ft
KlooGee Posted at 1-23 20:25
I agree with this and ask/request/implore it for the next FW update. The right side dial only being tied to zoom is extremely limiting (many of us pros will never use the "zoom" function).
We need need a quick way to manually adjust manual exposure. Currently the joystick can raise or lower the EV if in Auto exposure mode.
2022-1-23
Rrrick
Flight distance : 42162 ft
Yay! Thank you for adding Air 2s support!
2022-1-23
sduck
Flight distance : 4315098 ft
Thanks DJI!
2022-1-23
arizona mavic flyer
Flight distance : 1059072 ft
Yes, terrific news. Thanks DJI.
2022-1-23
Rrrick
Rrrick Posted at 1-23 20:37
Just tested the RC Pro with the new firmware update, and it synced up with my Air 2s, and I did a quick night flight, and it worked very well.  I’ll try and put it through it’s paces tomorrow.  Thanks DJI, good work!
2022-1-23
Monkey007
Flight distance : 73775046 ft
I was also looking forward to seeing some added customizing options for  C1, C2, and the 5D button, and most importantly the right dial, but couldn't really see anything new in there...
2022-1-23
DowntownRDB
Flight distance : 1722 ft
Another thanks for adding Air 2s support.
2022-1-24
TonyPHX
Flight distance : 11229610 ft
Sorry for the amateur question here this morning, but how do I get the RC Pro to update?  Do I have to plug into assistant for this?
EDIT / UPDATE : Ignore.  It did the update..  Just took a bit.  Thank you.
2022-1-24
RobZilla
Flight distance : 1057844 ft
TonyPHX Posted at 1-24 06:47
You should be able to update it over the air when you start the Fly app. Or you can use the DJI Assistant 2 app on your PC or Mac to update too. Just saw a YT video where the guy did it over the air looked easy.
2022-1-24
TonyPHX
RobZilla Posted at 1-24 06:58
Thank you RobZilla - you were 100% right - and it just finished.  Thank you!!!
2022-1-24
fans4c30b43b
Flight distance : 573484 ft
Does this update also update the version of RC Pro controller that came with the air2s bundle or just the ones that came with the 3?
2022-1-24
KLRSKIR
Flight distance : 28368625 ft
Great update, delivered as advertised. Thank you DJI!!!
2022-1-24
Mobilehomer
Flight distance : 18135846 ft
fans4c30b43b Posted at 1-24 08:13
I updated and tried mine that came with the Air 2S. It works great and now supports the M3.
2022-1-24
arizona mavic flyer
Yes. Same update and improvements. got the update when I turned on the controller and the Air 2S. There's a firmware update for the drone, and one for the remote. The Fly app will also update.
2022-1-24
fans4c30b43b
arizona mavic flyer Posted at 1-24 09:05
Awesome, thanks, been waiting for the clean HDMI the whole time. Can't wait to go home and update.
2022-1-24
roamer105
Flight distance : 3156145 ft
fans4c30b43b Posted at 1-24 10:18
Yes this would be great. I did test it with my 4K computer display connected to the HDMI output of the RC Pro. It actually matches the 4K resolution of the display and switching between mirroring and live works.
Problem is: I use a set of Fat Shark HDO2 goggles which are wonderful. However, even after the update the HDMI output will not maintain a connection with these goggles. It recognizes and sets the proper resolution but then promptly drops the connection. So, for me, the HDMI output is useless. The sad part is that the old Smart Controller's HDMI output works just fine with the HDO2 goggles.
The good thing is that there is an alternative via the USB-C using a USB-C-HDMI adapter cable. It works absolutely perfectly that way but of course the "mirroring" to "live" switching does not affect that output.
2022-1-24
KlooGee
Monkey007 Posted at 1-23 22:57
I don't currently have the RC Pro because of all these issues of lack of functionality.  The stock controller with no 5D, no right scroll wheel, and only a single Fn button pretty much does the same amount of functions as the RC Pro currently.  I can't see where it is worth the $1200 to upgrade to it until they actually make it full featured.
2022-1-24
hallmark007
Flight distance : 9827923 ft
KlooGee Posted at 1-24 11:37
I think features will come. It now is available for Air2s, so having one remote for both of these helps,  having it dedicated is a big help not using the phone is a great help. I know you can use a Mini iPad etc but these all cost money and involve more cables. I think the new option to buy without standard Remote in a combo will make it a good option.
2022-1-24
fans4c30b43b
roamer105 Posted at 1-24 10:52
Does it give you the option to change the resolution output the way the old smart controller does (when working from the hdmi port, not the usb-c)?
2022-1-24
Mobilehomer
I really like the new layout and look of the recording GUI. MUCH easier to navigate.
2022-1-24
Macman1
Flight distance : 246138 ft
"Added support to use with DJI Air 2S."  Is this for the bundled/combo or RC pro bought separately?
2022-1-24
JayOhio
Flight distance : 2289446 ft
Macman1 Posted at 1-24 21:08
I bought the RC PRO with the M3 and the remote now works with my Air2s, does that answer your question?
2022-1-25
Mobilehomer
I bought the Air 2S FMC with RD Pro. After the update, the M3 now shows up as an option in the fly app. I am anxious to see when other drones will be added.
2022-1-25
Rrrick
I bought mine separately and it now pairs with my Air 2s and works very well
2022-1-25
Mobilehomer
Does this update support the Mini 2  on the Air 2S version of the RC Pro?
2022-1-25
Macman1
Rrrick Posted at 1-25 10:11
Surprisingly, DJI support is still insisting that it is not possible. When I shared the link to this forum, the reply was this is for the bundled one only. When I argued further, the support person got agitated and asked me to go buy and check. This morning the email I got from DJI states the following:
"Regarding this, please kindly note DJI RC Pro shipped along with the DJI Mavic 3 is only applicable to DJI Mavic 3. Currently, DJI RC Pro for Mavic 3 does not support the DJI Air 2S. It is recommended to use the remote controller in the Air 2S combo. It will be supported with a firmware update in the future. "
2022-1-25
Rrrick
Macman1 Posted at 1-25 20:29
Too funny!
2022-1-25
snyper272727
Flight distance : 19428714 ft
4x the TX power over stock remote ;)
2022-1-26
fans4c30b43b
Mobilehomer Posted at 1-25 17:31
Mine didn't, too bad maybe another update later
2022-1-26
Mobilehomer
WE'RE IN THE FUTURE!!!!! WOW!!! NOW I'M REALLY CONFUSED!!
2022-1-26
fansdfc23d4d
Flight distance : 503215 ft
JayOhio Posted at 1-25 07:59
Every time I change the connection between the Air2s and M3 for the RC pro it downloads a small firmware and asks me to relink the drone. Do you have to do the same ?
2022-1-26
HubertAile
Flight distance : 6348120 ft
fansdfc23d4d Posted at 1-26 22:13
Yes same here :/
2022-1-26
djiuser_Ne499Notd4zt
Flight distance : 758904 ft
Switzerland
Hello DJI
I like when DJI makes new products.
But my opinion is, DJI should first ask, what are the most desired improvements who are
requested by customers. As example you can made on your website a CUSTOMER request
catalog and based on this information then create the desired product.
I was disapointed with the new Smartcontroller (RC Pro). Please compare what the competition
what they are able to develop.
Best Regards
Michele
2022-1-28
Switzerland
2022-1-28
KlooGee
snyper272727 Posted at 1-26 04:42
I've not seen anybody in the real world show they are able to get a substantively better signal back using the RC Pro.  Have you?  If anything, up until now, it seems like people actually get far more disconnects using it...
2022-1-31
djiuser_cR991F2y48nM
Cameroon
##### 100% @@@@@@@exclusive Gallstone for sale(^^+237674956802^^)@@
Ox Gallstones For Sale
Cow /Ox Gallstones for SALE MPPPPP
Buy high quality natural ox gallstone mppppp
Cattle Gallstones for sale mpppp
buy cow gallstones for sale in chizhou
Cow Bovine for sale in fuyang
Buy cow bovine for sale in Guangde
Ox and Cow gallstones for sale in China
Buy Ox gallstones in Hong kong
Cattle gallstones for sale in Hong Kong
Buy cow gallstones for sale in china
Cattle gallstones for sale in China
Whole ox gallstones for sale in jinjiang
broken ox gallstones for sale in Nanping
buy whole cattle gallstones in Quanzhou
buy broken gallstones for sale in China
Stones are traded in the following specifications:
100% whole stones
90% whole stones / 10% broken
80% whole stones / 20% broken
70% whole stones / 30% broken
60% whole stones / 40% broken
100% broken stones
100% ox gall powder
Contact
Email; bangjames70@yahoo.com
Whatsapp;( +237674956802)
Ox,Cow,Cattle, Gallstones
100% whole stones
100 % Broken and 100 %.
contact; WHATSAPP ( +237674956802)
EMAIL; bangjames70@yahoo.c0m
Quality and classification
Highest demand is for stones with the following features:
yellow golden orange colour;
stones with low specific weight;
large stones;
bili rubin content not less than 35%;
There is a demand for dark stones as well, but prices are considerably lower however.
100% whole stones
100% broken stones
100% ox gall powder
The stones have to have a natural smell of healthy, BSE free cattle. Liver stones, kidney stones, piping, moldy stones, blood stones, cholesterol stones and stones descending from other animals respectively are separated
Shipment
The shipment is proceeded according to the negotiated contract conditions via DHL. Depending on the request of the particular buyer the following documents go with the shipment:
2022-2-1
liuyipeng
Flight distance : 118031 ft
There is no waypoint for newer drones since the Mavic 2, and I heard rumors that Mavic3 won't have Waypoints just like all the new DJI Drons. What a disappointment DJI !!!!!!!!  What is wrong with you???? If you disabled the waypoint in the MINI and AIR line, I understand, it is to protect your higher-end product, the Trump Ban have brought you financial struggle, and there is a globe chip shortage, I understand,  you are increasing the price for Mavic 3, I understand, but no waypoint for the Mavic 3??????????  What the actual F___K????????? Mavic3 IS NOT A CHEAP DRONE!!!!!!!!!! WAYPOINTS It is not even a hardware-related issue!!! As an old user since phantom 2,  I really don't understand your decision making these days!!!!!!!!!!!! What is happening???? Are you trying to hand the drone market over to Skydio? ??????? RESPONS!!!! DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!DJI !!!!RESPONSE!!!!!!!!!!!
2022-2-1
DJIowCIPuser
Switzerland
Hello
Is it sufficient to update the RC Pro firmware to connect with the DJI-Air2S drone?
Or will the drone DJI-Air2S also need a newer firmware?What is the minimum DJI-Air2S firmware version required to work with the RC-Pro Smartcontroller?
Thanks for the answer
2022-2-11
12Next >
