Point/Spot Spraying with DJI MG-1P
1376 1 2022-1-24
rlc_1337
Brazil
From DJI Agras T16 and above, there is a possibility of Point/Spot Spraying using the DJI Terra (just like this video: https://youtu.be/fV1UV6eCcAU). I was wondering if the same can be accomplished with the Agras MG-1P as well?
2022-1-24
LI STL
Brazil
Hello,
I'm facing a problem with MG-1P and spot spraying. Is there some kind of limitation to do this?
I could successfully generate a flight route for Agricultural Application (with Fruit Tree - Spot Spraying Mode).
I have uploaded it to the cloud, but when downloading into the controller, this error message shows up:
Network Error. (even though the WiFi is working fine).
I have also tried exporting the file to a SD card, which the controller did correctly list, but on importing, it displays the following error message:
drone model: DJI MG-1P-RTK
drone firmware version: v02.01.0212
controller model: GL300N
controller firmware version: v02.01.0212
DJI Terra: v3.3.4 (tried with 3.3.0, and faced the same issues)
2022-4-13
