Osmo Pocket turns on, then turns off
5930 10 2022-1-29
NiceJoke
Russia
The problem is observed immediately after unpacking the device from the box. The problem is the following: when i try to turn on the camera, you can see how the gimbal begins to calibrate, but it obviously does not do it to the end - by turning left and right, and stops, although judging by the reviews of movements, there should be much more. Then, after the language selection appears on the screen, the camera turns off after a few seconds. The battery is fully charged. I tried with an inserted flash drive, and with another, and without it at all. And I connected to the phone - it didn’t help, I don’t even have time to activate the device in the application - the camera just turns off. I did not find solutions on the Internet.
I sinned on a possibly dead battery - but apparently everything is in order with it, and the problem has not gone away when the device is connected to charging. It can be seen that when connected to charging, the indicator blinks 4 times, which means that the battery is charged by more than 75%, and this charge should be enough for the device to function normally.
Video with problem -
2022-1-29
DJI Paladin
Flight distance : 318 ft
Hi, thank you for reaching out. We're sorry for the unpleasant experience. In this kind of situation, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support. Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your understanding and support!
2022-1-29
Blériot53
Flight distance : 6188465 ft
Have you tried switching on using the button on the right side of the unit?
2022-1-29
NiceJoke
Russia
Blériot53 Posted at 1-29 11:00
Sorry, but which button on the right is it?  It's just that, as far as I can see, there are only two buttons on the device - the video recording button (left), and the on / off button (right).
2022-1-29
Blériot53
NiceJoke Posted at 1-29 11:18
In your clip, you press the button on the BACK of the unit to switch it on.  There is a button on the RIGHT side of the unit to switch it on - that is, if you're using the Osmo Pocket 2.
2022-1-29
NiceJoke
Russia
Blériot53 Posted at 1-29 11:25
Oh, but this first version, OSMO Pocket
2022-1-29
Blériot53
NiceJoke Posted at 1-29 11:33
Ah. In that case I cannot help, sorry
2022-1-29
Montfrooij
Flight distance : 2560453 ft
I hope you get this fixed!
2022-1-30
NiceJoke
Russia
Montfrooij Posted at 1-30 11:45
Unfortunately, I could not fix this problem, I searched everywhere - I did not find a solution anywhere.
2022-1-30
Montfrooij
NiceJoke Posted at 1-30 23:47
Return to vendor then.
2022-1-31
HGDC84
Finland
I'd strongly recommend sending it back to the vendor - yes, it is a bit of a pain, but so is getting an expensive camera and then not being able to use it.
Hopefully your issue will be solved with as little hassle as possible!
2022-1-31
