help bettery light flashing
395 8 2022-1-31
lev surkov
Flight distance : 391955 ft
I havent flown my dji mini 2 in about 2 weeks, I was storing my bstteries outside the charging hub, now I plug them in and only two of them charge. the other one twice flashes the last two led indicators? what does thos mean? how do i fix it?
2022-1-31
lev surkov
a photo i just took
2022-1-31
Mrshuer11
Flight distance : 866286 ft
Romania
Try to discharge them , and also if the problem continues you can put them in the drone and try to charge it there. If the charging work inside the drone that means that there is an issue with the dock
2022-1-31
Johnny_J
Sweden
Any difference if you change the location in the hub for the failing battery with another location in the hub?
2022-1-31
BWJ
Denmark
Sometimes after weeks it can take up to ½ hours in the charger before it starts charging
2022-1-31
djiuser_nO2RdSW5BSUg
Flight distance : 80646017 ft
Poland
This signal means no digital communication with the battery. This could be a contact problem. In one of my batteries, I had to bend the contacts with a sewing needle.
2022-1-31
No Original Thought
Flight distance : 1364209 ft
See the second light bulb point at the top of page 24 in the user manual.
3 & 4 flashing means the battery is not inserted correctly - so probably a contract problem as someone else had already said.
2022-1-31
lev surkov
Thank you all, Apparently blowing hard on the contacts worked. thanks!
2022-1-31
DJI Stephen
Hello there lev surkov. I am sorry for the trouble this has caused before and it is great to know that you were able to rectify the said issue and for giving out how you have fixed the said issue. Have a safe and a happy filming always.
2022-1-31
