DJI Mavic 3 - Active Track 5.0 - New Firmware - Torture Test Thro...
4532 19 2022-2-5
DAFlys
DJI Mavic 3 - Active Track 5.0 - New Firmware - Torture Test Through the Trees - 4k
2022-2-5
Visual Air
Flight distance : 2710115 ft
Thanks for sharing DA Flys
2022-2-5
hallmark007
Flight distance : 12151329 ft
the AT is excellent on M3 , but it has its limits, its not a skydio so should be treated within its parameters.
Nobody is ever going to be walking in and out of trees like this filming themselves like that. But it was a tough test of the drone.
2022-2-5
DarthSLR
Flight distance : 2169370 ft
Thanks for finding and sharing!
2022-2-5
Suren
Flight distance : 13528625 ft
New Zealand
This YouTube does not learn. He crashed the drone once and now wants to tempt fate again.
2022-2-5
Niknik
Flight distance : 1595640 ft
Greece
Active track5.0 and APAS 5.0 are awesome with some bugs in some decisions that it makes but DJI will fix this sooner or later. The big problem is that it does not use a hybrid Active track and GPS track. Or produce a beacon-like device to do it. This is making the Active track less equal to Skydio 2. If DJI hear and do this and of course fix some bugs the Mavic 3 will have the best Active track and APAS. One more thing is to make it faster. With this hybrid tracking, it will give priority to bypass obstacles and without hard data processing, if it loses the target well ok it will find it again with the GPS of the remote and after visual again.
2022-2-5
GaryDoug
Flight distance : 1264639 ft
Suren Posted at 2-5 12:58
As a retired test engineer, I can identify with the efforts, bad or good. It's figuratively called "pushing the envelope".
2022-2-5
GaryDoug
Niknik Posted at 2-5 15:27
Well. I don't want to give up smooth video just because some folks want to run around/into some trees. Apples and oranges.
2022-2-5
Grimtheviking
Flight distance : 12584416 ft
Its got better since the last update, but its got its limits. A gutsy test and good viewing. Thanks for sharing.
2022-2-6
Niknik
Greece
GaryDoug Posted at 2-5 19:27
It can have both with a digital switch in DJI fly app somewhere below apas with label active track and below a switch with visual or hybrid. Visual will be cinematic and Hybrid like a skydio 2 situation.
2022-2-6
DAFlys
Grimtheviking Posted at 2-6 11:59
no probs Grimtheviking.
2022-2-6
Montfrooij
Flight distance : 2560453 ft
Thanks for sharing!
2022-2-9
DAFlys
Montfrooij Posted at 2-9 02:07
Thanks for sharing!
No probs Monty
2022-2-10
Montfrooij
2022-2-10
fansbed32e61
New Zealand
Montfrooij Posted at 2-10 00:30
I am finding AT on the M3 a lot less usable than my M2 Pro. Tracks fine walking around. My main interest is kayaking. The drone tracks me to the waters edge but as soon as I get in the kayak it looses me. I’ve tried a few things - sun behind drone etc. Always wear bright clothing. Presumably the area/shape being tracked changes too much. For all that the M2 Pro was more reliable.
2022-2-18
Suren
fansbed32e61 Posted at 2-18 16:50
Question- Do you have the drone set to track you has a person and then expect it to track you still when you jump into the kayak?
2022-2-18
fansbed32e61
New Zealand
Suren Posted at 2-18 22:33
Yes - I make sure the person icon is showing before hitting go
2022-2-19
Montfrooij
Ah yes, I see.
2022-2-19
Suren
fansbed32e61 Posted at 2-19 12:21
When you sit in the kayak, the drone sees a different shape and not the shape of a person standing or walking anymore hence it will lose you. For a more accurate active track you need to select this mode when you are in the kayak and not walking.
2022-2-19
fansbed32e61
New Zealand
Suren Posted at 2-19 13:08
I will have to find a waterproof cover for the controller
2022-2-20
