Can you change minimum altitude above the ground?
555 3 2022-2-6
djiuser_rUPo8vECVlTQ
Slovakia
Hello, I control DJI Spark programmatically using mobile remote controller on Android Mobile SDK but I am restricted from flying lower than 0.3m above the ground. So I would like to know what are the possibilities to either change this minimum height or disable it completely so I would be able to fly lower and not be forced to land.
Thank you for help.
2022-2-6
Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
g_config.flying_limit.user_avoid_ground_enable_0=0
g_config.flying_limit.avoid_ground_and_smart_landing_enable_0=0
tested on mavic2 and air2 mini2
2022-2-6
Slovakia
Mats Bohlinsson Posted at 2-6 07:59
Hello, so If I understand correctly, the only way would be to change Spark flight parameters through DJI Assistant software in PC?
2022-2-6
Mats Bohlinsson
Sweden
djiuser_rUPo8vECVlTQ Posted at 2-6 08:15
Yes, or use other free desktop programs to change parameters.
You can do it programmaticly. Not officially supported by sdk though.
2022-2-6
