DJI Mini 2 5.8 GHz don't work after update
123Next >
24425 115 2022-2-6
ivanmini
Flight distance : 183983 ft
Brazil
Hello friends,
After receiving alert to update the firmware about control remote I got problems with the frequency in 5.8GHz after this update. The connection only works with the controller very close to the aircraft, about 2 meters away at most. To solve the problem I need open settings and set the operating frequency to 2.4GHz manual (disable dual band). I couldn't downgrade the update because there are no options in the DJI assistant 2 app. Has anyone else had this issue and managed to resolve it? I'm in Brazil and the 5.8GHz frequency is allowed here.
Soluction:
Hello everyone, I would like to inform you that I was the creator of the topic and I was very disappointed with the brand for stating that the problem was with the smartphone. Probably, this response was given by someone without technical knowledge for the function.
As we have seen in some responses from owners of the Mini 2 who had the same issue, this occurs due to overheating in the 5.8GHz chip during the update process, causing damage to it. The brand should have stated in the manual that the drone should be placed in a well-ventilated environment during the update process to avoid this problem.
Furthermore, overheating in these models occurs not only during the update process but also in the simple process of pairing with the remote control on the 5.8GHz frequency while the drone is not yet flying.
As we have also seen, the problem is resolved by replacing the chip (which must be done by an electronics technician). However, the cost of replacement is high compared to the value of the drone; perhaps it is not worth making this replacement and continuing to fly only on the 2.4GHz band until the end of the drone's lifespan.
However, this is a risky flight operation since if the drone loses the 2.4GHz signal, it automatically tries to reconnect on the 5GHz frequency. I do not recommend using the drone in areas at risk of accidents, such as during long flights or in enclosed areas.
The problem occurs with DJI Mini 1, 2, and 3, according to other topics that I have read.
Thank you very much to everyone who replied to the topic and helped to discover the issue!
2022-2-6
DJI Stephen
Hello there ivanmini. I am sorry for the trouble this has caused and thank you for reaching out. May we please know what is the model of the mobile device that you are using please for us to be able to isolate the said issue? Thank you.
2022-2-6
ivanmini
Brazil
DJI Stephen Posted at 2-6 20:08
Thank for you answer:
Smartphone: Xiaomi Redmi Note 8
Dji Fly: Version 1.5.9
Remote controller: V04.11.0032 (current)
Dji Mini 2: V01.03.0000 (current)
2022-2-7
DJI Stephen
ivanmini Posted at 2-7 10:35
Hi there ivanmini. Thank you for the reply and for these information. Kindly please try using a different recommended mobile device to see if the issue will persist? Upon checking the said mobile device ( Xiaomi Redmi Note 8 ) that your are using on the DJI Fly application. I am sorry to say that the said mobile device is not recommended for the said DJI application. DJI would suggest using a recommended mobile device for the DJI Fly application for compatibility and reliability purposes. There is a possibility that the Xiaomi Redmi Note 8 will be able to work on the DJI Fly application. But however, since it's not yet optimized with the said DJI application we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Fly application while using it. For reference, I will post a link where in you can check the recommended mobile devices for the DJI Fly application ( https://www.dji.com/downloads/djiapp/dji-fly ). Thank you.
2022-2-8
ivanmini
Brazil
DJI Stephen Posted at 2-8 21:49
The problem occurred after updating the firmware for the remote and not after updating the flight app. Before I bought the drone, dji informed me that the app was compatible with the Mi Note 8 device, as you can see in the attachment sent by the seller. In fact, I just downgraded the application (reinstalling previous version) and the problem was not solved: it only connects to 2.4GHz and the configuration is not saved, we need to change it every time before flying.
O problema ocorreu após atualização do firmware para o controle remoto e não após atualização do aplicativo de voo. Além disso, antes de eu comprar o drone, a dji informava que o aplicativo era compatível com o dispositivo Mi Note 8, conforme é possível ver no anexo que o próprio vendedor me  enviou. Inclusive, eu acabei de fazer downgrade do aplicativo (reinstalar versão anterior) e o problema não foi resolvido: conecta apenas em 2.4GHz e a configuração não fica salva, precisamos alterar toda vez antes do voar.
2022-2-9
lualeses
Dominican Republic
I’m having the same problem with my mini 2. I think the firmware on the control is the problem. I can only use my drone in 2.4 band. Previously I was flying normally dual-band.
I tested the controller and the Drone in every device I have (iPhone 11 pro max and iPad Air 2) having the same behavior in both.
Selecting 5.8 band or dual band turns in connections lost and bad signal even within 1-2 meter apart or something in between.
2022-3-3
djiuser_sGN8d147KYIP
Flight distance : 25643 ft
Brazil
Im have sane problema, any solution ?
2022-3-26
djiuser_rqn7rCwMfe91
Brazil
I'm also having the same problem.  I can only run on 2.4ghz.  In dual band or 5.8GHz it loses the signal even being close.  It also happened after the last update.  My smartphone is an S22 ultra.
2022-3-27
Brazil
we need a solution from dji!!
2022-3-27
djiuser_zDx1yjqorB06
Flight distance : 80538 ft
Brazil
I'm also having the same problem, there are a lot of people in the same situation, it's amazing how dji doesn't take a stand on the subject
2022-3-28
Brazil
I've just read some reports, that the last updates take a long time, causing the coreboard to overheat and damaging the chip responsible for Wi-Fi 5.8, especially in countries with hot weather !!!!!
2022-3-28
djiuser_hJ4QTiRFDpKa
Brazil
O vcs estão fazendo . Atualização falhas para resolver as cagadas no mavic 3 .   E ferrando com mini 2 air 2 e air 2s
Falhas constantes de sinal . Drones parando de funcionar
Pior que hubson ????
2022-3-28
Burstmode
Flight distance : 258379 ft
It seems that there is an issue with the firmware, and DJI was informed back in early February.  There has been no response from DJI since 8 February -- when DJI's response was basically, "use a different phone."
Since then....crickets.
2022-3-29
Marcelodronerj
Brazil
Estou com o mesmo problema e não consigo solução.
Liberem o downgrade para a versão anterior do firmware.
Essa atualização está prejudicando milhares de usuários.
Não tenho mais segurança em levantar vôo, o drone perde sinal com poucos metros.
O erro é de vocês, não é nosso.
Não importa o smartphone que estamos usando, antes era totalmente funcional, agora depois dessa atualização do firmware ficou uma porcaria.
2022-4-6
Ginkuma
Dominican Republic
I am having exactly the same issue after last update, DJI has rendered the mini 2 useless, they don't take responsibility, even after many respectable people on YouTube have made the videos showing proof that the last update messed everything up. I think we should all get together and sue DJI. How dare them do this to us after spending hundreds of dollars on their products... This is unforgivable...
2022-4-11
Ibrahim Shiyaam
Maldives
Hello everyone, i have same problem on my mini2. If any found a solution for this…pls help
2022-4-17
ivanmini
Brazil
lualeses Posted at 3-3 20:24
I'm sure the problem was caused by an error in the remote control update firmware. Before updating there was no problem, the problem appeared after updating the controller firmware. In the "DJI Assistant" application there is still no option to reinstall the old firmware version. DJI has not yet resolved this issue and is ignoring customers.
Eu tenho certeza que o problema ocorreu por erro no fimware de atualização do controle remoto. Antes de atualizar não havia problema, o problema apareceu depois de atualizar o firmware do controle. Na aplicação "DJI Assistant" ainda não existe opção para reinstalar a versão antiga do firmware. A DJI ainda não resolveu este problema e está ignorando os clientes.
2022-5-14
army2408
Flight distance : 723707 ft
Singapore
Hi there, i have the same issue and exactly the same situation as described by many other Mini 2 users here: very weak 5.8Ghz signal after firmware update. If dual band is selected, it seems to be selecting 5.8 Ghz automatically and the Mini 2 will get disconnected just within 5 meters. Can you please clarify if DJI acknowledged of this issue? Thank you.
2022-5-29
DJI Stephen
army2408 Posted at 5-29 17:55
Hi there army2408. Thank you for the reply and for giving out these information. I will forward this matter to the designated DJI department for evaluation. Thank you.
2022-5-30
djiuser_iU87ichHzXQA
Flight distance : 33461 ft
Bangladesh
Same problem. Really frustrating.
2022-6-24
Gregotec
Flight distance : 816434 ft
Brazil
Firmware 1.4 detonated with mini 2 bad signal, I updated to Firmware 1.5 did not fix it.  My mini 2 only works on 2.4ghz auto
2022-6-24
DukeofDrones
Flight distance : 12885007 ft
Same issue. There is an issue with this.
There is no option to roll back the firmware.
Not great DJI . Please fix this .
2022-6-26
djiuser_9HhEptYnz7Xc
Same problem with my Mini 2. I had full confidence flying it and had no issues before the update. Before knowing the problem, I flew my drone on the lake and got connection lost in the middle of the flight, can't get the connection back on. So the drone returned home but bump into a tree and fell into the water, thankfully it's only 1meter deep and I manage to take it out right away. I'm aware that I shouldn't have flown close to trees and water but there's no other good place it on my situation.
This could all have been avoided if only I was aware with this issue. Now I can only fly my drone in 2.4ghz manually.
My phone is Iphone 12 pro.
2022-7-13
Ben Greyling
Flight distance : 338159 ft
South Africa
This is what happen`s to my Mini 2 the drone it is only 3 day`s old Fly`s great, but the 5.8 as advertized will be great.
2022-7-14
leomak
I have the same problem,
I borrow my friend remote to try, still have same problem.
And use my  friend mini 2 (no update) to connect my remote, it can us  5.8GHz.
So  this the mini 2 update problem?
How can i to fix this problem?
2022-7-18
manuelcad
Flight distance : 9589439 ft
Brazil
After updating to 1.6.9 and updating the controller, the 5.8ghz connection fails on the drone side, where is the solution to the DJI problem
2022-7-22
manuelcad
Brazil
I WAS USING SANSUNG S21 5G DEVICE IS IN THE LIST AND I TRIED AS THE SANSUNG S22 AND THE PROBLEM CONTINUE
2022-7-22
manuelcad
Brazil
Marcelodronerj Posted at 4-6 10:02
Blz amigo tambem esto tendo este mesmo problema seu so que o meu so ocorreu na atualização 1.6.9 e do controle tambem. gostaria de saber se vc conseguiu resolver seu problema. Como vc mesmo falou fica complicdo voar desta forma
2022-7-23
manuelcad
Brazil
Ginkuma Posted at 4-11 06:21
teve alguma solução estou com o mesmo problema
2022-7-25
Arefin Bashar Arif
Flight distance : 457799 ft
I'm using the Air 2s and am experiencing the same issue. The issue began approximately a week ago when I was using the 1.6.4 version. I haven't updated the app/drone in over a month, so it's not due to an update. I upgraded the app to 1.6.9 and the DJI firmware to xx.2190 today with no success. It only works with 2.4GHz frequencies. Even when the drone is literally about 100 meters away, I am periodically disconnected from my devices (both Android and iPad).
2022-7-30
Dupalio
Flight distance : 87064 ft
Brazil
Exactly the same problem as everyone else, I updated and I got sick! dji how will it be? how many more will disable their drones?
2022-8-18
Dupalio
Brazil
Até hoje nada de solução irmão eu fui a vitima da atualização hoje
2022-8-18
ivanmini
Brazil
They put a moderator on the forum who doesn't know what he's talking about.
Meanwhile, we are flying without safety and may cause an accident.
If they are unable to solve this problem, they could at least immediately say: "We are unable to solve this problem" and close this useless forum.
2022-8-19
Dupalio
Brazil
Alguém sabe dizer se um controle novo resolve o problema? estava pensando em investir no smart controller , por causa da saída hdmi . Se resolver nem vou esperar suporte dji
2022-8-19
djiuser_JVRfQbZtzLpn
Flight distance : 1509629 ft
Brazil
Estou com o mesmo problema. Aeronave perde o sinal muito perto.
Só consigo usar se coloco em 2.4. Em Auto perde o sinal com 10 metros.
Preciso de uma solução para o problema.
Dji Air 2
Motorola moto z3 play.
Controle atualizado. Drone atualizado. Android atualizado.
2022-8-20
Brazil
Dupalio Posted at 8-19 13:16
Tenho dois controles. Com os dois, o mesmo problema.
2022-8-20
Dupalio
Brazil
djiuser_JVRfQbZtzLpn Posted at 8-20 12:13
Resolvi o problema, enviei para a jxDrones 500 reais e o drone voltou ao normal. Extremamente decepcionado com a DJI a parte ruim de ser a única gigante do mercado sem concorrencia a altura ficamso a emrce desse tipo de tratamento com o cliente
2022-8-30
WillyBsDrone
Same problem here.
Using Samsung Galaxy Note9 (not that it is relevant).
The firmware update did not show any errors.  I can no longer control the 2.4/5.8 GHz frequency selection, and the drone loses signal directly over head before reaching 150ft.
Drone is now useless.  One day before long planned filming event.  This is last minute equipment failure will cause untold losses.
DJI has lost major reliability points.
2022-9-2
dimboost
Puerto Rico
Hi. Same problem here.
Using Samsung Galaxy A50 with Mini 2. Before update everything works fine, After update  I can no longer control the 2.4/5.8 GHz frequency selection.
2022-9-13
djiuser_XUkK3eZfGoYP
Malaysia
@ DJI, are you working on a solution for this issue?
2022-9-24
123Next >
