Whay happened to upward gimbal rotatio setting?
5853 25 2022-2-16
BrianKushner
Flight distance : 44281716 ft
This setting is now gone from both versions of the Fly app. I was looking to turn it off since I'm now having an issue when I rotate gimbal upwards using the wheel it continues to travel even though the setting is at 5.
2022-2-16
DJI Paladin
Flight distance : 318 ft
Hi, Brian. We're sorry for the trouble that this has caused. We will forward this query of yours to our designated team for attention. We will keep you posted once we have an update. Thank you for your understanding and support.
2022-2-17
Glhs958
Flight distance : 753130 ft
I am also missing this now in the fly app v1.5.9.
2022-2-18
Grimtheviking
Flight distance : 11796312 ft
Hi Guys, just tried both of the above functions and both Ok and working fine on my android device, 1.5.9. Maybe try reinstalling the app?
2022-2-18
Glhs958
Grimtheviking Posted at 2-18 08:14
I did that yesterday dl fresh installer from dji and installed on my android device. That still would not explain its missing also from the Apple device.
Android version v1.5.9-1015 Apple version v1.5.9-600
we are refering to the setting of
Allow Upward Gimbal Rotation that was between Gimbal Mode and Advanced Gimbal Settings.
2022-2-18
BrianKushner
Did you have it connected to the drone and the drone running? It appears in the app when it’s not connected to the drone and the drone is turned on but once the drone is on and running it disappears.
2022-2-18
BrianKushner
The reason I even looked for it to turn it OFF is I'm having an issue with the gimbal continuing to rise even after I let go of the wheel. Even with the low setting of 10 No matter how slow I set the number it will travel a good distance when I let go of wheel...Something isn't right.
2022-2-18
Grimtheviking
I miss understood here, I also don't have that setting on start up, but on my upward gimble movement with pitch speed set at 12 and smoothness at 18 it glides to a smooth stop just after releasing the wheel, it do's not continue movement as I can see, only to a smooth stop. Ideal setting for me. Sorry I cant be of more help.
2022-2-18
BrianKushner
Does anyone know how I might go about fixing this? I did gimbal calibration..Not sure what else to try. I was hoping to turn off the upward movement...
2022-2-18
Monkey007
Flight distance : 73775046 ft
Also noticed the 'on-off' button was missing too. But I assumed you've already played with the 'smoothness' setting and couldn't make the gimbal tilting to stop rapid enough?
2022-2-18
BrianKushner
Monkey007 Posted at 2-18 13:43
Correct. I’ve always had at 15. Moved to 10. Even tried 5. The setting controls how fast the gimbal moved but nothing is stopping the travel after I let go of wheel. Going to make a video.
2022-2-18
Oulala
where is that button ???
2022-7-27
djiuser_tJzIheJADCOa
DJI Paladin Posted at 2-17 02:02
Hello, is there now an option to fix this problem? I wanted to allow upward gimbal rotation, but I don’t have the button or the advanced gimbal setting button.
2022-11-5
HomerMomer
Hi, could customer service please provide an update as to what is going on with the missing 'upward gimbal rotation' on the Mini 2? The product specification page still states that the gimbal range is -90 degrees to +20 degrees if the corresponding option is turned on (otherwise -90 degrees to 0 degrees). However, right now, I only get -90 degrees to 0 degrees. There is no option in the 'Control' tab to extend the upward gimbal rotation range. This renders the drone completely useless for cinematic photography of sunsets and cloud formations.
Aircraft firmware: 01.05.0000
RC firmware: 04.11.0034
App version: 1.8.0
Addendum: So I played around a little bit even considering downgrading the firmware (ended up not needing to do that) and installing an older version of the DJI Fly App (that did not work on my iPhone 12 Pro Max as its operating system is too new). However, I had my old phone, an iPhone 5s, lying around and installed the DJI Fly App on it, connected the aircraft and, to my pleasant surprise, it had the 'Allow Upward Gimbal Rotation' option in the 'Control' tab. I checked it, tested it on the Mini 2 and all worked fine. The only difference that I see is that on the iPhone 5s the App version is 1.8.10 while on the iPhone 12 Pro Max it is 1.8.0 (even uninstalling the App and reinstalling it using a QR code from the DJI website only resulted in 1.8.0). The iPhone 5s runs on an older version of iOS. So that may explain the difference in DJI Fly versions. In any case, I have a workaround for the time being and anticipate the required option to be available once 1.8.10 is available for iOS 15/16. On the positive side, using the much smaller iPhone 5s actually makes it easier from a handling perspective. The older and smaller screen constitute a limitation, but I am good with it for now as not being able to rotate the gimbal to 20 degrees really resulted in unacceptably un-panormaic panoramic pictures of sunsets and clouds.
2022-11-6
djiuser_IA74tFltlrUg
So weirdly I got my dji mini 2 second hand 3 days ago and the gimbal look up option was there so I enabled it, I fired up my drone today and just 3 days later from my initial purchase the options disappeared, strange, I can still look up with the gimbal but no longer switch it off, just 3 days later the option has disappeared, I’m on an I phone se, an old one but running on the latest IOS, if there was a problem with how new or old versions with the app was or IOS’s on I phones why would I have the option only 3 days before to now not have it, my I phone hasn’t done any over night updates and the firmware on the dji app has always said firmware up to date, what the hell has happened here DJI.
2022-11-10
So this morning from the post I posted last night, the 20 degree has not only gone as an option but gone from the gimbal itself, I can’t even look up now, what’s going on
2022-11-10
djiuser_7VNoA0lF5NDR
Glhs958 Posted at 2-18 05:59
[view_image]
Was there a fix for the gimbal up option that was missing?
2022-11-11
djiuser_BcYntetqpgh5
I am having the same problem, the gimbal up option is missing. How we can solve that?
2022-11-13
Mobilehomer
Flight distance : 18135846 ft
BrianKushner Posted at 2-18 18:02
It's not the speed. it's the smoothness setting. Try around 18-20.
2022-11-13
fans69b478d2
Flight distance : 446969 ft
Any news about this issue?
2022-11-18
fotonews
Did anybody find an answer to this issue? hardware, firmware? How do I allow upward gimbal rotation? Dont have that option showing in iPhone 12 Pro, DJI Mini 2.
2022-11-20
DJI Tony
fotonews Posted at 11-20 09:35
Hi there, fotonews. We have responded to your inquiry in the other Forum thread. Please check this link for the response: {https://forum.dji.com/thread-279672-1-1.html}. Thank you and have a nice day.
2022-11-20
djiuser_HUBhyCpQjkke
I write a review for DJI Fly app in app store,
And I wish it will fix sooner.
2022-11-30
And I wish it will be fixed sooner.
2022-11-30
2022-11-30
Heckle0
This has bee going on for a while. Fix it please. Its not like you have to design something new. Its a feature we had that went missing. Fix it. Might start shopping for a new drone elsewhere
2022-12-26
