DJI FPV controller right stick off centre
1242 2 2022-2-21
ryanrtjh
Hi, i recently got back to flying my dji fpv and i noticed the right stick became slightly off centred when returning the stick to the centre via the spring tension. This now causes my aircraft to continue to roll slightly left if leaving the right stick completely untouched at all. any ideas how to fix? I compensated this off centre using a larger dead zone in liftoff, but I am afraid in actual flight the slight left roll will still remain.
2022-2-21
DJI Stephen
Hello there ryanrtjh. I am sorry to know that you are having this issue with the remote controller of your DJI FPV and thank you for reaching out. Since you are having this issue, I would recommend for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do there best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2022-2-21
djiuser_5qTZ7RrkRceQ
Norway
i have the same problem just with my left stick have you found a solution yet?
2023-6-7
