DJI DRTK2 Tribrach Adapter
850 3 2022-2-24
DJI4Survey
Flight distance : 6484478 ft
Hey All,
I have given this .STL file to a few ppl on here over the years to assist in getting better setup accuracy with the D-RTK 2 Mobile Station.
The file is compatible with most standard tribrach setups.
I will say that the feet are the weakest part of this design, and if you already have a tribrach adapter, you can slice the threaded bit off the top and add a 5/8th threaded hole.  I have that file somewhere if you need it.
Good luck.
https://www.thingiverse.com/thing:5251551
2022-2-24
AshleyGeek
Flight distance : 570466 ft
That link doesn't work, 404 on thingiverse
2022-2-28
DJI4Survey
https://www.thingiverse.com/thing:5267472 try that.
2022-2-28
DJI4Survey
2022-2-28
