Power System Error 30210
9230 4 2022-2-25
crunchycone
Philippines
HelloI have a Mini 2 with a total flight time of 17 hours.
One day I was trying to fly it but it prompted me with power system error.
But I found out it was only happening on 2 of my batteries.
One battery didn't give me a power system error and I was able to fly it.
I also noticed when I use the other two battery that gives the power system error, the DJI sound cant be heard on the drone when turning it on, but when I use the other "good" batter, the dji sound can be heard.
I read posts that this may be a drone board failure, but for me it looks like a baterry error.
Can this be fixed?
Also this happened when I updated the DJI fly app
power system error
power system error
2022-2-25
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. According to your description, the DJI Fly app prompts "Power system hardware error". We cannot remotely troubleshoot and solve the issue. To ensure your flight safety, we suggest that you send the device back to DJI for testing. We will provide comprehensive after-sales services to you. Thank you for your understanding and support.
2022-2-25
FlyingOverABQ
Flight distance : 103245 ft
If its a battery error, its also kind of odd that it happened to two batteries at roughly the same time, which points to the drone being the error, so you have reasons to suspect both the batteries and drone.   I'd make sure DJI support understands this and allows you to send the two suspected batteries back.  You might also try cleaning the contacts on the battery and drone as a last ditch effort to try to fix, and start with fully charged batteries.
2022-2-25
djiuser_hYGd0KV3aMOF
Philippines
I have a mavic mini and I had the same issue. when I use 2 of my batteries they have the error, but the other one does not. and this also happened when I did an update on the app. After the update my drone turned off, and after I turned it on, the issue popped up. Is there a way to reset the battery? or can you send an update to fix this issue? thanks
2023-1-1
djiuser_eDOLSuAaOfs8
Flight distance : 240 ft
South Africa
djiuser_hYGd0KV3aMOF Posted at 1-1 16:18
Hi, I just had the same thing, 2 of my batteries, which are brand new give a power system error but the 3rd one does not, seems like a bad batch of batteries
2023-5-3
