Dji Phantom 3 Advanced Not Linking to remote
710 2 2022-2-25
hoodog
Hello everybody I got a used phantom 3 advanced and changed the main board and flown it many many times now without an issue. that was until yesterday i had my first crash. one prop was a bit broken then when i tried to take off it flipped and rattled around a bit on its side on ice for couple seconds. Now it does not want to seem to connect to my remote anymore. see attached video. I really hope that my ofdm module is not bad. the led on the ofdm module is solid red when remote is off and as soon as i turn it on, it blinks red and green.. so its getting some signal but maybe not the right data? Is there anything i can check?
https://youtu.be/ykQw64JQ-io
2022-2-25
DAFlys
Hi! You might be better off posting your question in the 'products' section of this forum.  That is way more active.    -   https://forum.dji.com/forum-129-1.html
2022-2-26
DJI Paladin
Flight distance : 318 ft
Hi, thank you for reaching out. We're sorry for the unpleasant experience. In this kind of situation, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support. Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. To check the warranty period for each part, you may click this link: https://www.dji.com/service/policy. Thank you for your kind and understanding.
2022-2-26
