Drone not lifting off
1637 7 2022-2-25
GammaGonzo
Flight distance : 195594 ft
Greetings all,
I just got the FPV via amazon. I updated the firmware on the drone, goggles, controller and even the fly more batteries. Everything has been linked and I can see through the goggles, there is no error messages and I am not flying in restricted airspace. The drones rear lights are blinking green and everything looks good to go. I take the controller and push the sticks to start it up, it starts up. I use the left stick to take off in N mode/mode 2, and it barely makes noise. The right stick reaches high rpms and moves very slightly before turning the motors off. Has anyone else had this issue?
2022-2-25
Visual Air
Flight distance : 2710115 ft
Did you check the props for proper orientation?
2022-2-25
GammaGonzo
Visual Air Posted at 2-25 20:22
My friend… let me tell you…. I did not
2022-2-25
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Kindly please make sure that you already activated the said components and make sure you install the propellers in proper positions. I will post a tutorial video wherein you can follow the steps on how to properly set up the unit. If the issue persists, kindly please send us a screenshot of the error message on the DJI Fly app. Please keep us posted. Thank you
2022-2-26
Visual Air
GammaGonzo Posted at 2-25 20:24
Maybe check that and report back. Make sure the props are on the correct motors.
2022-2-26
GammaGonzo
Visual Air Posted at 2-26 07:22
It was the propellers. It works!
2022-2-26
Visual Air
GammaGonzo Posted at 2-26 07:54
Good stuff. Happy flying.
2022-2-26
GammaGonzo
Visual Air Posted at 2-26 08:35
I assumed the props would be a full set in each box, when in fact, the props are two seperate designs in two seperate boxes. I also didnt realize they were color coded.
2022-2-26
