Issues with DJI Transmitter/Betaflight?
1918 6 2022-3-2
heliovue
After finally getting all the build components in, I finally had a chance to get my 3" cinewhoop put together. Unfortunately, I am unable to see any sticks/switch movement in Betaflight and the Servo Setup within the DJI Goggles. Stick movement is recognized when calibrating in the DJI Goggles, and the dial can be used for navigating menus within DJI Goggles.
Setup:
Caddx Vista with DJI Camera
DJI Goggles V2
DJI Remote (Mode 2)
T-Motor F7 Mini 45A Stack for DJI
Everything has been installed, removed, cleaned, resoldered, and reinstalled during troubleshooting per MFR instructions.
Firmware updated on all hardware including BF and BF Configurator.
Remote bound to Vista and DJI Goggles.
UART 1 set to Serial Rx (dedicated pin in harness)
UART 3 set to MSP/Config
Configured for Serial based reciever, SBUS provider. Telemetry checked per installation instructions.
Remote is not responsive when sbus_baud_fast is enabled or disabled via CLI. I have also confirmed that the Goggles and BF baud protocols are matched.
I'm at an absolute loss as this is my first HD system. Any help or advice is appreciated.
2022-3-2
Unhinged
#Quick Reply HI have the same situation.
2022-3-4
heliovue
Unhinged Posted at 3-4 16:28
#Quick Reply HI have the same situation.[Image]
What hardware are you using? Air unit or Vista/Link?
2022-3-5
fansa276e243
Did you resolve this issue? As i am experiencing the same problem.
Regards, Daniel
2022-4-30
ro_flyer
Flight distance : 7557283 ft
Brazil
great views!
2022-5-12
chitter00
Switzerland
Hello @heliovue
Have you found a solution to this problem?
Kind Regards
Chitter
2023-4-3
heliovue
chitter00 Posted at 4-3 09:52
Hello @heliovue
A replacement fixed it. Have you checked your antenna and ensured you have the correct orientations regarding M&F? I stupidly ran into that on the new one before putting the right one on.
2023-4-3
