DJI Fly - Device Management
5757 6 2022-3-3
Kryztov Pilot Pal
Flight distance : 22837100 ft
Jamaica
My DJI FPV does not appear in the Device Management
section of the DJI Fly App. My Mini_2 appears however. Is
there a problem?
2022-3-3
DJI Stephen
Hello there Kryztov Pilot Pal. I am sorry for the trouble this has caused and thank you for reaching out. May we please know what is the model of the mobile device that you rea using please and kindly please try to uninstall and reinstall the DJI Fly application from this DJI Link ( https://www.dji.com/downloads/djiapp/dji-fly ) to see if the issue will still persist? In addition, kindly please sync all of your flight records before uninstalling the DJI Fly application on your mobile device for you not to loose your previous flight information. If the issue persist kindly please try using a different recommended mobile device for us to be able to isolate the said issue. Thank you.
2022-3-3
Kryztov Pilot Pal
Jamaica
Hi. I use a Samsung Note 10+.
2022-3-3
DJI Thor
Flight distance : 13602 ft
Kryztov Pilot Pal Posted at 3-3 01:07
Hi, there. Please follow the steps above to check whether the abnormality persists.
2022-3-3
fansb326352c
Flight distance : 291864 ft
I got the same issue.. tried the steps above but it’s not working for me. The Mini 3 Pro and the Avata are in device management, the FPV will only appear when turned on and connected.. how come?
I read it has something to do with the fact the FPV doesn't have Flyaway coverage so you cannot bind it to your account like the MAvic or Air for example, is this correct?
Like i said in the first place when the goggles are on and connected to my iPhone the FPV is on and the RC it will appear in device management, but it will not stay in device management like my Mini 3 Pro and Avata when i'm correct.
2023-5-21
Milan17977
Anyone who can confirm what’s written above?☺️
2023-5-21
Dominik__W
Flight distance : 1112218 ft
Poland
I have exactly the same. DJI FPV is visible in the My Devices section when it is turned on and the goggles are connected to the DJI Fly app
2023-5-22
