Question about IMU reading disappearing.
516 10 2022-3-12
kyalami
Flight distance : 17352513 ft
Sweden
Today when I was out to do some flying, I noticed something about the IMU that I have not seen or thought of before.
When putting on the power to the drone, I check the IMU, compass and the direction of the drone to where the arrow is on the map and that they align. Everything showed fine and I started the prop’s and took off. I left that screen on for the IMU by mistake and then saw that there was no reading from the IMU any more. Did some testing and found that the IMU reading disappeared as soon as I started the prop’s.
  Is this normal, that when you start the prop’s, the IMU reading disappears?
2022-3-12
Sean-bumble-bee
Flight distance : 15997 ft
Can you post a set of before and after screen captures?
2022-3-12
DJI Stephen
Hello there kyalami. Thank you for reaching out and for sharing these information with us. Kindly please post a sample screenshot showing the issue for us to see and can assist? Thank you.
2022-3-12
kyalami
Sweden
Hi,
Please find screen shot when drone is turned on and on the ground. N o motors running.
Here is a screen shot when flying.
I just noticed today that when motors are on or I am flying, it says "MOVING" and the green line is gone. Could it be so, that when the drones motors are on and you are flying, that the IMU date can not be shown?
2022-3-13
Sean-bumble-bee
Great, thanks.
They disappear when I start the motors on my M2Z too. They reappear when the motors are stopped.
I will check a Pro later.
2022-3-13
hallmark007
Flight distance : 9827923 ft
kyalami Posted at 3-13 00:45
Hi,
It does show you at the bottom . “In Use” and all you see is a dot to confirm its working correctly .
2022-3-13
hallmark007
Sean-bumble-bee Posted at 3-13 04:20
Great, thanks.
See post 6 , its quite normal.
2022-3-13
Sean-bumble-bee
hallmark007 Posted at 3-13 04:36
Uuum, wrong number perhaps, I typed post 6, :-) ......but post 7 is good.
2022-3-13
hallmark007
Sean-bumble-bee Posted at 3-13 04:43
Sorry I was trying to fool you , “a couple of weeks to early” ;+).  Yes 7…
2022-3-13
kyalami
Sweden
Great, thanks.
OK, thanks for confirming that your does this to, so it seams to be normal.
2022-3-13
kyalami
Sweden
hallmark007 Posted at 3-13 04:35
Yes, thanks for your reply, that's right. I saw this at the bottom also, as well as the little dot in front of the ACC0, but the green line was not there any more. Just wanted to check this, as I have never thought of this before. Today I as out flying again and the drone behaves normal as usaul.
2022-3-13
