Aloft LAANC Authorization taking forever
904 5 2022-3-13
Marleyman
Hi all, I used the Aloft App to get Authorization to fly in a Class D Airspace - just some drone photos for marketing of a local business located within that Class D airpace.
I used the Aloft App on my phone to request an Authorization to fly and it's been a week without any answer yet.
I was under the impression that the Aloft Authorizations were more "realtime" - but I may lose this Drone Job if I don't get the Authorization by Wednesday.
Can anyone offer some advice in this situation please?
Should I cancel and try a different LAANC App that does offer actual realtime Authorizations?
Also, I don't think I can request a DJI Custom Unlock Code without first getting the Authorization to upload to the DJI Custom Unlock Code System?
Appreciate any help you can offer.
Many thanks
2022-3-13
kenstruct
Flight distance : 309344 ft
Not sure how it might be affected by different days and locations but my expierence getting a LAANC in a similar situation the permission came within a couple of minutes and simply had a caveat of 300ft max instead of the normal 400. I'd assume you've tried making a request each day? I think Aloft was the app I used, it took longer to create the account than it did to get the LAANC response.
2022-3-13
JEZ2
Flight distance : 336204 ft
If your request was at or below the grid ceiling, it should be pretty much instant.  If you requested a height above the ceiling, it's a longer process because it is a manual approval.
2022-3-13
TonyPHX
Flight distance : 11229610 ft
The request you made must have required "further coordination".  I would not worry about losing the job.  Safety is the first priority.  And, any other drone operator would require the same authorization.
2022-3-13
Marleyman
JEZ2 Posted at 3-13 17:02
This was exactly the issue. I just got instant approval for the day/time I need to do the job at 300ft. Submitting it originally for 400ft was the problem. Many thanks all!
2022-3-14
DJI Stephen
Hello there Marleyman. Good day and thank you for reaching out. Since this is a 3rd party application that you are using. I hope that our fellow DJI Co pilots who have used this application can give out the best recommendation and information with regard to this matter. In addition, you may also contact our DJI Flysafe department by sending an email to flysafe@dji.com for additional assistance. Thank you.
2022-3-15
