UKMoose
Flight distance : 3657552 ft
Just found this posted by a dji moderator, hope it helps, not sure I know how to do it,
Last part should do it I hope.
Hi, thank you for reaching out and we're sorry for the trouble that this has caused. Press and hold the Function button on the aircraft for four seconds until you hear two beeps which indicate that the aircraft has switched to mobile device control. Launch the DJI GO 4 app and tap the icon in the top right corner of the screen. Next, scan the Wi-Fi QR Code on the aircraft to start the connection procedure. When "Start Flight" is shown on the app, it indicates that the connection is successful (or manually select the Mavic Air Wi-Fi in the mobile device Wi-Fi list and enter a password). If the password was still incorrect, you can reset the WiFi SSID. To reset the Wi-Fi SSID and password, press and hold the aircraft’s Function button for about 6 seconds, until you hear three beeps. Then connect the mobile device and drone and change Wi-Fi SSID and password under Wi-Fi settings. Please keep us posted. Thank you for your kind and understanding |
