Montfrooij
Flight distance : 2408829 ft
DJI Thor Posted at 3-16 01:23
Hi, there. Sorry for the inconvenience. After having a try, we found that there was no abnormality here. Could you please try to change other networks to see whether it persists? We also forwarded your issues to our related team. Thanks for your understanding.
home.php?mod=spacecp&ac=avatar:464 Uncaught TypeError: jQuery(...).scrollbox is not a function
at HTMLDocument.<anonymous> (home.php:464:26)
at c (jquery.js:3:7857)
at Object.fireWith [as resolveWith] (jquery.js:3:8658)
at Function.ready (jquery.js:3:3266)
at HTMLDocument.H (jquery.js:3:695)
home.php?mod=spacecp&ac=avatar:61 [Report Only] Refused to load the script 'https://bam-cell.nr-data.net/1/04a84ecc46?a=258626997&v=1215.1253ab8&to=MVBXMBRSDUdRWkReDggaYBYPHAtbXVweRwkW&rst=1110&ck=1&ref=https://forum.dji.com/home.php&ap=105&be=485&fe=1053&dc=903&perf=%7B%22timing%22:%7B%22of%22:1647530195470,%22n%22:0,%22u%22:472,%22ue%22:472,%22f%22:4,%22dn%22:4,%22dne%22:4,%22c%22:4,%22ce%22:4,%22rq%22:6,%22rp%22:452,%22rpe%22:453,%22dl%22:473,%22di%22:903,%22ds%22:903,%22de%22:932,%22dc%22:1053,%22l%22:1053,%22le%22:1061%7D,%22navigation%22:%7B%7D%7D&fp=550&fcp=550&at=HRdURlxIHkk%3D&jsonp=NREUM.setToken' because it violates the following Content Security Policy directive: "script-src 'self' 'report-sample' 'unsafe-inline' 'unsafe-eval' www.googletagmanager.com www.googleadservices.com googleads.g.doubleclick.net js-agent.newrelic.com www.google-analytics.com assets.djicdn.com store-api.dji.com click.dji.com forum.djicdn.com". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
Element.insertBefore @ home.php?mod=spacecp&ac=avatar:61
conversion_async.js:72 Unrecognized feature: 'attribution-reporting'.
wd @ conversion_async.js:72
8[Report Only] Refused to load the image '<URL>' because it violates the following Content Security Policy directive: "img-src 'self' data: fcmatch.youtube.com fcmatch.google.com <URL> m.dji.com cm.g.doubleclick.net i.ytimg.com forum11.djicdn.com forum33.djicdn.com forum.djicdn.com forum22.djicdn.com forum44.djicdn.com googleads.g.doubleclick.net trc.taboola.com <URL> store-api.dji.com cm.g.doubleclick.net store-guides.djicdn.com".
DevTools failed to load source map: Could not parse content for https://forum.djicdn.com/static/ ... rum.umd.min.js.map: Unexpected token < in JSON at position 0
elastic-apm-rum.umd.min.js:1 [Report Only] Refused to connect to 'https://bam-cell.nr-data.net/events/1/04a84ecc46?a=258626997&v=1215.1253ab8&to=MVBXMBRSDUdRWkReDggaYBYPHAtbXVweRwkW&rst=11119&ck=1&ref=https://forum.dji.com/home.php' because it violates the following Content Security Policy directive: "connect-src 'self' apm-server.djiops.com www.google-analytics.com analytics.google.com stats.g.doubleclick.net bam.nr-data.net".
(anonymous) @ elastic-apm-rum.umd.min.js:1
U.r.<computed> @ elastic-apm-rum.umd.min.js:1
r.xhr @ nr-1215.min.js:1
c @ nr-1215.min.js:1
u @ nr-1215.min.js:1
r.runHarvest @ nr-1215.min.js:1
(anonymous) @ nr-1215.min.js:1
elastic-apm-rum.umd.min.js:1 [Report Only] Refused to connect to 'https://bam-cell.nr-data.net/events/1/04a84ecc46?a=258626997&v=1215.1253ab8&to=MVBXMBRSDUdRWkReDggaYBYPHAtbXVweRwkW&rst=41659&ck=1&ref=https://forum.dji.com/home.php' because it violates the following Content Security Policy directive: "connect-src 'self' apm-server.djiops.com www.google-analytics.com analytics.google.com stats.g.doubleclick.net bam.nr-data.net". |
