New DJI Terra Released (3/16/2022)
1362 2 3-15 19:39
DJI Support
Flight distance : 2408 ft
South Africa
Overview:
  • Release Date: 2022.3.14
  • Version: 3.3.4
Fixes:
  • Fixes issue where users with online licenses cannot use premium functions offline within first two days after restarting DJI Terra.
  • Fixes issue where outputs are layered after enabling Optimize Point Cloud Accuracy when processing LiDAR data collected from multiple flights.
  • Fixes issue where DJI GSR or DJI Pilot cannot properly display downsampled DSM files generated by 2D urban reconstruction.
  • Fixes issue where language of quality report always defaults to English after setting language option for DJI Terra when installing for the first time.
  • Fixes issue where operation stutters when modifying results of identified objects in Agricultural Application.
  • Fixes issue where drawings are incorrectly displayed when modifying results of identified objects in Agricultural Application.
Note:
  • After updating firmware, users are unable to continue modeling or change reconstruction file format for missions from v3.1.4 and earlier versions.
  • After updating firmware, users must restart modeling to continue an incomplete reconstruction mission from v3.1.4 or earlier version.
  • After changing file format, users must restart modeling to continue a completed reconstruction mission from v3.1.4 or earlier version.
  • Users are unable to view reconstruction output produced in v3.3.0 if the firmware is reverted back to v3.1.4 or earlier versions.
  • After renaming the mission in v3.3.0, users are unable to view reconstruction output in v3.1.4 or earlier versions.
  • Zenmuse L1 calibration function is required with Zenmuse L1 with firmware version higher than v02.04.01.08 (excluding v02.04.01.08).
  • Agras T10 or T30 users should use Agras drones with up-to-date firmware version to access Agricultural Applications.
  • Agras T16 or T20 users should use Agras drones with specified firmware version to access Agricultural Applications (Please contact DJI Support for the firmware).
  • DJI Terra Permanent License update and maintenance fees: Users can update DJI Terra to any version released within the first year of use free of charge, starting from when license is activated. From the second year onward, users must pay for version updates annually.
  • The Detailed Inspection function is now compatible with DJI Pilot V1.9.0R or later versions.
Supported Aircrafts - Route Planning
  • Phantom 4
  • Phantom 4 Pro
  • Phantom 4 Pro V2.0
  • Phantom 4 Pro + V2.0
  • Phantom 4 Advanced
  • Phantom 4 RTK (MONITOR RC)
  • Phantom 4 RTK (NO-MONITOR RC) (Only supports importing Detailed Inspection planning route)
  • Matrice 300 RTK + H20 Series payloads (Only supports importing Detailed Inspection planning route)
  • Mavic 2 Enterprise Advanced (Only supports importing Detailed Inspection planning route)
3-15 19:39
Frontliner 2020
Philippines
thank you for the update...
3-15 20:23
Coinhunter50
Flight distance : 39564 ft
Does DJI offer training courses for their phantom 4 series? I want to learn mapping/crop monitoring and more.
4-10 05:41
