M200 User Defined Data Transmission
878 1 2022-3-15
frogking
South Korea
Hello, friends.Firstly, sorry for my bad english.
I'm testing data transmission with M200 drone, and using PSDK development board, which is recommended from DJI, STM32F407-EVAL.
I saw that the board's OS is freeRTOS and then I can't use High speed data transmission.
I thought that when I transmit data, the channel of data transmission is UART ( Command Channel ), and the bandwidth is <=3072bytes. ( Channel and Bandwidth Information is from Document )
With those information, I wanted to know the exact bandwidth, so I tested with my Dummy data Transmitter.
When I sent about 2000bytes data per second, the App(developed with MSDK) ran very well.
But, when I sent about 2500bytes data per second, the App went down.
About this two test, I just think that, with real drone control command, the bandwidth can be smaller.
However, when I sent 20bytes per 0.01second, the App went down or the portion of data was taken.
How can I explain this problem, and handle it...?
Have you ever handled this problem like data transmission with freeRTOS board?
If I want to use High speed data Transmission, what should I do?
Is there no way without using Linux OS?
Thank you for your advice
2022-3-15
DJI Thor
Flight distance : 13602 ft
Hi, there. Sorry for the inconvenience. Please try to contact our related team via dev@dji.com. We will help you out. Thanks for your cooperation.
2022-3-16
