Broke an arm, JB weld to the rescue
3058 14 2022-3-19
Whoreable
Flight distance : 1775299 ft
Save $50 or more and get a bottle of JB Weld Steel reinforced epoxy, set a few layers really thin over until the arm is in place then go crazy with some extra coats, it should take a few days to finish the process because its slow cure time but its rock solid and only like $10
better yet it cures almost the perfect body gray as the stock fpv
2022-3-19
DAFlys
Nice fix,   any pictures?
2022-3-19
DowntownRDB
Flight distance : 1722 ft
Interesting fix.  Have you flight tested it yet to see if it will hold up under max speed, dives, etc.?
2022-3-19
DJI Stephen
Hello there. Good day and thank you for sharing these information with us. Have a safe and a happy flying always.
2022-3-19
Whoreable
DowntownRDB Posted at 3-19 03:46
Flew it in manual mode tonight, did a few flips and dives at 13 degree camera angle, it felt really solid. So when it first crashed the arm broke and the motor was slightly binding up but I didnt notice it. So when I JB welded it back together originally I was unaware of the motors slight resistance to spin.
Flying the first test in normal mode was perfect, i was going in circles around my basketball court with ease and then I gave it some up throttle, a few seconds later it pitched forward into a flip and hit the snow below about 20 feet. Recovering the drone I had no idea the motor wasnt spinning totally smooth and caused an imbalance when flying up.
So I ordered a new motor and landing gear motherboard, installed them and found that the red wire to the motor had snapped inside the drones now fixed arm. So i used my soldering iron and put a small hole into the landing gear so i could route the new red wire to the mainboard. Its not very pretty but the drone flys now!
2022-3-20
DowntownRDB
Whoreable Posted at 3-20 00:05
Interesting, very interesting.    Glad it worked out.
2022-3-20
Depp
Flight distance : 1868796 ft
Interesting. Can you post a few pics. Just crashed mine yesterday, ripped off an arm and again at the motor and ripped off the sensors. I guess this one is a goner.
2022-3-20
KlooGee
Flight distance : 16783757 ft
Depp Posted at 3-20 03:23
I’ve not had to do it yet, but from what I’ve read, DJI repair prices on the FPV drone are very reasonable if you aren’t able to do it yourself.
2022-3-20
Depp
KlooGee Posted at 3-20 04:37
Will ask them, thanks.
2022-3-20
GTS 350
I have never had jb Weld work on anything I tried it on (it has always failed). I would stick to a standard 2 part epoxy for plastic
2022-3-21
Whoreable
GTS 350 Posted at 3-21 17:22
well that must be your fault, i have used JB weld on ATV motor oil filter housings that were cracked, and they generate much more vibration and heat that this drone will ever face.
i suggest you use jb weld to the instructions because jb weld is incredibly reliable in my history
2022-3-21
Whoreable
no photos, just glue it back together if the break wasnt clean enough you may have to purchase another arm, its very easy to re-wire and assemble if you arent a total idiot.
2022-3-21
Depp
Whoreable Posted at 3-21 20:57
Well, I guess mine was gone far too much for my repairing skills...
2022-3-21
GTS 350
Whoreable Posted at 3-21 20:56
Yeah its my fault DB look up the 1000s of jb weld failures.
Good luck with your jb weld repair.
2022-3-22
Whoreable
she aint pretty but she flys in manual mode and better than my non crashed backup
drone by None None, on Flickr
2022-3-23
