Battery Maintenance
3535 2 2022-3-21
vdaerthe
Turkey
Hi everyone. I just bought my DJI FPV and during the test flight it said that battery maintenance required. So I charged the battery fully and currently waiting for 24 hours to pass. According to manual I should discharge the battery until 20% remains by hovering the drone at low altitude. Unfortunately I will not be able to go outdoors today to do this. My question is this, is it possible to just put the battery into the drone and just power it on in the room and wait until 20% battery remains? I heard that it will take approximately one hour to deplete the battery by this method so if I wait around 45 minutes it will be enough. I am very inexperienced in this subject and any help will be very appreciated. Thanks.
2022-3-21
Nidge
Yes you can do this, and it will be kinder to the battery.
I used to do this with my Phantom 2 batteries and 3DR Solo batteries. In fact the current 3DR Solo APP has this process automated. If you want to speed the process up a bit without going outside, or risking death and destruction in your house, you could arm the quad with the props off and leave the motors running.
2022-3-21
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We apologize for the inconvenience. This is a known issue and DJI engineers are currently working on positioning and solving it. When the prompt "Battery Repair Required" appears, please ignore it and fly as usual. This prompt will not affect the flight safety. Please continue to use the device worry free. Thank you for your valued support.
2022-3-21
