Bob-Mini-2
![](https://forum44.djicdn.com/data/attachment/common/aa/common_14_usergroup_icon.png) Second Officer
Flight distance : 73114 ft
Rockbyter, to me, if the battery is inserted into the Charging Hub, and the battery is backwards of the normal charging position,
and there is NO electrical connection to the battery, then through the circuitry IN the battery that we are told will do the proper
thing - all should go well. The battery will slowly discharge down to the level that circuitry is designed to bring it. After flying Mini 2,
I leave the batteries alone for a day, then recharge them to a full charge, remove them from the hub, place them on a shelf and
forget about them till the next time I am able to fly. IF the period since I recharged them has been more than a week or two,
I check them by putting each in the hub or Mini 2 and seeing what the lights have to say. TWO steady and ONE Blinking is about
40 to 60%, which according to the manual is nice. IF I am going to fly, I charge the batteries I will need - back to full charge, in the hub.ALL of my batteries DO discharge slowly, when they are NOT electricly connected to anything! Hope this helps???.
Edited: 4/25/2022
*I checked the manual for the Mini 2, and it recommends that if the battery is in storage or not being used for a while, that it should be brought down to 30% or slightly less.
Not me, I am happy with the way things are, as I stated above. ????? **
