New firmware v1.03.30.20 STILL HAVE GLITCHES IN 360 ROLLS!!
1594 22 2022-3-24
Cobani
Flight distance : 612503 ft
Argentina
I can't believe it... I bought this camera specially for FPV because the size, weight and image quality... but it's an absolute garbage.
Old firmware:
4K60 - 1/120 - Rocksteady - WB 5500 - D-Cinelike: Glitches in 360 side rolls
4K60 - 1/120 - Steady - WB 5500 - D-Cinelike: NO GLITCHES
New firmware
4K60 - 1/120 - Rocksteady - WB 5500 - D-Cinelike: STILL glitches in 360 side rolls
4K60 - 1/120 - Steady - WB 5500 - D-Cinelike: NOW WE HAVE GLITCHES IN THIS MODE TOO!!
I tried everything (horizon calibration, hard reset, main storage, SD storage, etc) but the glitches are there.
So... I have a expensive camera that have glitches or jumps in the footage when I do 360 side rolls.
I can't use Rocksteady because I have glitches.
Now I can't use Steady because I have glitches.
I can't use GyroFlow to stabilize in post because we don't have the gyro data.
SO... I CAN'T USE THIS CAMERA FOR FPV!!!! I'm still using GoPro 8 with ZERO ERRORS in the same configuration, no matter what, I don't have any hiccup in the footage. Always clean.
What do I have to do with this camera? Throw it away and no longer trust DJI?
How we can do FPV freestyle with ANY SORT OF STABILIZATION?????? THERE'S NO WAY!!!!!
I'm very angry... I can't believe it. The camera keeps collecting dust because it ruins any recording.
TESTS:
4K60 - 1/120 - NO EIS - WB 5500 - D-Cinelike: NO GLITCHES - ABSOLUTE GARBAGE WITHOUT STABILIZATION
4K60 - 1/120 - Steady - WB 5500 - D-Cinelike: GLITCHY
4K60 - 1/120 - Rocksteady - WB 5500 - D-Cinelike: GLITCHY
What can I do? Throw it away and buy more GoPro or Insta360? I CAN'T BELIEVE IT!!!!!!
2022-3-24
fansfe82067d
I'm sorry for your disappointment.  My immediate reaction is that you are using a shutter speed that is likely to be too low for EIS to handle in this situation.   EIS works by comparing frames, and if the shutter speed is too low, there is likely to be motion blur in the frames which messes with the frame-to-frame comparison.  As I recall it from another thread, 1/300 is a better shutter speed for EIS to work (and that's with any EIS camera).
2022-3-24
DJI Thor
Flight distance : 13602 ft
Hello, there. Sorry for your inconvenience. Is there everything normal when it‘s used in other situations without installing on FPV? If not, please provide other related videos for us to do further confirmation. Thanks for your understanding.
2022-3-24
djiuser_06uVCiKt99Ra
Flight distance : 11890 ft
My main goal for buying that camera was for for FPV and I am in the same position as you ... The main goal of filming in 30fps with a fix shutter speed is to make a natural blur that is pleasing for the eyes . Combined with the stabilisation it makes a good and smooth experience in video.
What's the point of making a camera that much expansive when you get to have better result with lower priced camera ....
2022-3-24
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
South Africa
Hi Cobani.  Thanks for the gyro data advice. we will consider it.
would u plz try 4k120fps with shutter speed 1/120 s, to see whether the issue remains?
2022-3-24
Cobani
Argentina
fansfe82067d Posted at 3-24 01:41
I understand that, but THIS DOESN'T HAPPEN IN MY GOPRO 8. The rule of "double the shutter speed of the FPS" must be done to have a pleasant video. With GoPro there's no problem.
So, it's an inmature EIS.
2022-3-24
Cobani
Argentina
djiuser_06uVCiKt99Ra Posted at 3-24 04:15
It's my same think!
2022-3-24
Cobani
Argentina
DJI-ytao Posted at 3-24 06:36
If I record on 4K120, the shutter must be 1/240 (double the frame rate). I will try.
2022-3-24
Visual Air
Flight distance : 707234 ft
Did DJI ever advertise that it could be mounted to a FPV for 360 rolls? You maybe asking for something that was never advertised. If it was I apologize. I just do not remember seeing it attached to any fpv drones during launch.
2022-3-24
Cobani
Argentina
Visual Air Posted at 3-24 11:25
ACTION CAMERA... sounds good to you?
Come on... none of the other action cameras have this problem.
2022-3-24
Visual Air
Cobani Posted at 3-24 16:59
It is an Action Camera I absolutely get it.  Attached to FPV may not be it's forte.
Maybe it is something DJI will fix in future firmware updates.
2022-3-24
DJI-ytao
DJI R&D Squad
South Africa
Cobani Posted at 3-24 07:19
if u want the motion blur(for the speed)
it is ok u set shutter 1/120secs,  u can also export into 60fps so the footage should be the same.
120fps steady is different with 60fps,  it might solve the issue.
2022-3-24
djiuser_xSwSveIHap0D
New Zealand
Hi Cobani,
why does the shutter have to be double the frame rate? Is this the same for any framerate?
2022-3-24
DJI-ytao
DJI R&D Squad
South Africa
djiuser_xSwSveIHap0D Posted at 3-24 23:06
Hi Cobani,
it is about 180 degree shutter rule.
https://www.xdynamics.com/blog/t ... -cinematic-video-2/
my own understanding is :
one frame to next frame, the object move to A and B with 1/fps second.
since real world object moves continuously, our eye will catch the blur of a fast moving object.
180 degree shutter speed 1/(2x fps) makes sure the "continuous" look, because
if there is a blur, this two frame object will be linked together with 1/(2xfps) exposure blur.
looks like continues.
it works for 30fps and 60fps.
for 120fps, if the final output is slowmotion, then 1/240 sec shutter is OK.
if the output is normal speed video I shall double it actually.
because 120fps is too smooth for human eye, the distance between A and B is too close to need the shutter blur to connect.And for the final output video maybe 60fps, the 1/120 sec shutter should be more suitable.
2022-3-25
DJI-ytao Posted at 3-25 03:59
https://www.youtube.com/watch?v=awXIFeqhXsI
so for a 2.7k or 4k video output to be able to have a good smooth blur effect with the stabilisation what would be the correct combination ? 60fps filming with shutter speed at 120 ?
2022-3-25
New Zealand
By asking about this, I was trying to point out to what the guy in the video says at the very end. 180 degree shutter is used to make moving things appear as in film (or what “your eyes sees in real life”), but film is played in 24/25/30 fps. If you are shooting in higher framerates and not slowing down your video to 24/25/30, the motion blur from a 180 degrees shutter won’t look “cinematic”.  Movies that have high framerate action sequences don’t need 180 degrees shutter.
TL;DR The “one over twice the framerate” rule doesn’t make much sense if your videos are in 60 or more fps when viewed.
2022-3-25
Cobani
Argentina
djiuser_xSwSveIHap0D Posted at 3-25 12:26
But when you are piloting an FPV drone, you don't know when you need or like to have slow motion or normal speed until see the final footage.
That's why we normally use 4K60 1/120. The final video it's reduced to 24/30FPS with normal speed and motion blur. BUT you have the flexibility to grab some parts of the same shot and do slowmotion at half speed.
2022-3-26
Visual Air
BTW Nice Rossi collection you have there.
2022-3-26
New Zealand
Cobani Posted at 3-26 10:43
I don’t know what your software does, but if you are not slowing down your 60fps recording when converting to 30fps, you’ll have the wrong shutter speed.
Anyway, this is not that important and a bit off topic. At the end of the day, there is a bug with the EIS, and you need to be patient, because issues like that are not easy to reproduce and fix. While waiting for DJI to figure it out, I’d prioritize using settings that allow the “stabe” to work and give up on having “perfect” shutter speed. (or just use another camera if you like the ease of use and video quality better)
2022-3-26
Anyone would be great enough to share what would be the best way to counter this EIS BUG ( for now ) until they fix it ?
What could be the best possible combinations of settings that could achieve a some kind of natural blur for filming our FPV video ?
Shutter speed , fps etc
It's getting a little confusing as of right now for me as I just
Want to produce good videos without having to test like 10 different combinations .
Thank you in advance .
2022-3-27
DJI-ytao
DJI R&D Squad
South Africa
djiuser_06uVCiKt99Ra Posted at 3-27 03:10
if u shoot in 4k120fps.
there is little chance to come across the issue.
2022-3-30
DJI-ytao
DJI R&D Squad
South Africa
Hi .Cobani
would u plz take a glance of messages I sent?
does 4k120 solve the issue in your occasion?
plz let me know your thoughts. and PM ur Dji account so that we will keep in touch for the beta firmware .
2022-3-30
DJI-ytao Posted at 3-30 19:15
Hi .Cobani
I would be willing to try the beta firmware
2022-3-31
