Auxiliary LED
6136 11 2022-3-24
pjglad
In settings, I turned ON the auxiliary LED but the liight does not turn ON. Am I missing something? Thanks.
2022-3-24
hallmark007
Flight distance : 12400594 ft
Its set to on, but if its bright it wont come on. You need to wait for low light. Or set a dedicated button to switch on manually.
2022-3-24
pjglad
AerialZup2 Posted at 3-24 13:11
Nope. That's not correct. It won't turn on unless the drone is airborne. It will come on, even if bright, while you are flying and you turn it on. Hallmark didn't give you correct information.
Thank You...
2022-3-24
hallmark007
You don’t want to listen to that fool.
You’ll find in the photo the aircraft is not airborne and the props are not turning it hasn't been flying. But the Led is on.
2022-3-24
hallmark007
AerialZup2 Posted at 3-24 13:23
You're welcome. Sometimes people confidently state things which are incorrect. Glad to straighten it out.
Look at the photo. Is that what you call airborne
2022-3-24
Mobilehomer
Flight distance : 18150351 ft
hallmark007 Posted at 3-24 15:21
No, but that is a 2S, not M3.
2022-3-24
hallmark007
Mobilehomer Posted at 3-24 15:26
Coming from you that’s hilarious, you spend most of your time here quoting that you don’t own an M3 . So would you call this airborne, or are you just here to feed the troll…
2022-3-24
EFRPIC
Stop this endless back and forth.
I don't care how many accounts you both have...the call-outs are just stupid. Corrections are fine...calling each other out is just a waste of your time AND ours.
2022-3-24
hallmark007
“Airborne “In The Air After Take Off”.
2022-3-24
Mobilehomer
hallmark007 Posted at 3-24 16:00
[view_image]
No, twit. I was just pointing out a FACT! I do know that not all DJI drones operate the same. re - RTH on the M3 is different from RTH on the Mini 2. Now I know the Aux light on the 2S and the M3 work the same. Thanks for the info.
2022-3-24
DJI Stephen
Hello there pjglad. Thank you for reaching out and for this inquiry. The DJI Mavic 3 Auxiliary Bottom Light can be set in the DJI Fly application, it is automatically enabled when the environment light is too weak. Kindly please note that the Vision System cameras performance may be affected when the Auxiliary Bottom Light is enabled. Thank you.
2022-3-24
AJ squared away
I'm not sure why you would want to have it on in full daylight unless you just want to see if it works ? I just was curious last night and tried it using the safety setting only to land and it works great . The manual says don't turn it on during take off . Not sure but maybe the sensors get confused .
2022-3-27
