Video distortion after upgrading to latest firmware
12Next >
2562 67 2022-3-25
Trzcina
Flight distance : 458937 ft
Poland
Hi All Mini2 users.
I write this post to warn you not to take the latest upgrade of mini2. I did for both controller and the drone, and here is new wonderful video quality received with this update.. Check the roof line, what a beatiful conversion from a straight line to a parabolic curve!!! I still have dji care, I am sending this crap to them:
https://drive.google.com/file/d/132TSegdS9mi-GfRnXDl1fX7zdpp6YgN0/view?usp=sharing
2022-3-25
DAFlys
Odd,  Ive done the firmware and not had any issues.
2022-3-26
Labroides
Flight distance : 9991457 ft
So I checked the roofline and it's perfectly straight.
What are you complaining about?
And why are you doing anything with this soft, cached, reduced-size image anyway?
Use the actual imahe files fromthe SD card.
2022-3-26
yogi053
Flight distance : 26104915 ft
Optical illusion perhaps? Caused by camera angle and wavy horizon?
2022-3-26
Landey
Not possible to download your file without begging for access.
Roofline is NOT straight (see picture), there's a distinc wobble. Maybe rolling shutter effect.
But we need to see the video.
2022-3-26
Trzcina
Poland
Labroides Posted at 3-26 02:37
[Image]
So first if all this is not a cached image, this is a still frame captured from movie file. That is point #1. Now, point #2 is, check your theorerically perfect straight yellow line you have overlayed onto the roof, and conpare with black part of roof and horizon. Still see nothing? Be more precise, try to fit parabolic curve and you'll see which is more accurate. I will send the the yt link to the movie. And no, I do not complain. I have compared to movies I have done earlier. I can prove it with side to side. There is nothing to complain other than pure facts.
2022-3-26
Mhinc
Flight distance : 151467 ft
Trzcina Posted at 3-26 02:51
So where is the link to the video on YouTube?
2022-3-26
Blériot53
Flight distance : 6269839 ft
Strange.  It looks more like a thumbnail image than the full res. you might expect.
2022-3-26
Labroides
I still can't see what you are complaining about?
Here's another perfectly straight line.
2022-3-26
Labroides
Blériot53 Posted at 3-26 03:33
Not surprising as it's 2325 x 1257.
Much smaller than full resolution.
2022-3-26
Trzcina
Poland
Labroides Posted at 3-26 03:44
Here's another perfectly straight line.[Image]
Do the same with horizon... put the thin line, with thick line you will mask everything... or.. just leave it. I will show it on the movie.
2022-3-26
Trzcina
Poland
Mhinc Posted at 3-26 03:17
I'm outta home, but will upload it, raw and in slomo. The deformation is there.
2022-3-26
Trzcina
Poland
yogi053 Posted at 3-26 02:41
But this illusion is everywhere: with horizon, with roof.. and movies I made in the past do not have this illusion...
2022-3-26
Trzcina
Poland
I have reviewed it again and you actually show the problem very well. Check bottom yellow line above gates 6543. That is the warp i talk about.
2022-3-26
DJI-Osmo-User-1
So you know for a fact that the roof is perfectly flat? Did you use your electronic transit theodolite integrated with electronic distance measurement (EDM) to prove your theory? Obviously your a civil engineer to make such claims.
Was there any heat haze to distort, either way I agree with all the others in that your wrong.
2022-3-26
Tuxtard
Flight distance : 9975610 ft
Serbia
Which resolution did you use? DM 2 has image distortion on 2.7k mode from the start.
2022-3-26
Trzcina
Poland
DJI-Osmo-User-1 Posted at 3-26 08:30
Video will open your eyes. Stop being rude, it is there.
2022-3-26
Trzcina
Poland
Tuxtard Posted at 3-26 10:05
That is precisely 2.7K @ 60FPS but I have never seen that before in this mode. Have other movies.
2022-3-26
Trzcina
Poland
Another example before I will post the video. I assume all roofs should be parabolic and for some of users here it is perfectly normal. Attached a movie still with thoroughly drawn straight lines. Download and zoom please. You will see by your own eyes I'm not inventing.
2022-3-26
Trzcina
Poland
Another still from video, and another perfect straight line and no reason to complain...
2022-3-26
DJI-Osmo-User-1
Next you be telling us the back not as high as the front,
2022-3-26
nOxxxx
Flight distance : 80646017 ft
Poland
The image distortion in the mini 2 was there from the beginning. It is most visible in the 2.7k image. I have described it here before. image distorsion
2022-3-26
Trzcina
Poland
DJI-Osmo-User-1 Posted at 3-26 10:53
When you cannot beat my thesis with arguments, it is time to be rude. So pathetic.
2022-3-26
Trzcina
Poland
Here is the video link: DJI MINI 2 Video Distortion
https://youtu.be/_jamL2glDto
Observe little bit below horizon line at the center of image, also seen perfectly in rotations.
EDIT: I am uploading hi res version. See next posts.
2022-3-26
Trzcina
Poland
nOxxxx Posted at 3-26 11:06
And this is the greatest answer of this thread, thanks!
That's exactly what happened with the first bunch of firmwares for Mini 1.
It can be fixed by firmware.
It looks like they forgot to add the perspective correction for the new video modes (compared to the old Mini)
2022-3-26
Trzcina
Poland
@nOxxxx, do you observe the same in 4K mode? Or is it only 2.7k? THanks in advance.
@@DJI Stephen can you push for solution?
2022-3-26
nOxxxx
Poland
In the 4k30 and 2.7k30 images, there is much less distortion in the center of the image, where the eyes are focused. I stopped using the 2.7k60 due to visible image distortion. Look carefully at my test charts from the attached link. Everything is clearly visible there.
2022-3-26
BWJ
Denmark
Easy to see, when you know where to find,  but have not noticed before now
2022-3-26
Trzcina
Poland
BWJ Posted at 3-26 12:53
Indeed. Devil is always in details but I can tell: I noticed immediately after fw upgrade. I fly a lot, record a lot, watch a lot. I will check with 4K.
2022-3-26
Bashy
Flight distance : 2354357 ft
Your top yellow line is covering the distortion, without your top line, you can clearly see that the dark area between your 2 lines goes from thin to thick, thin to thick...Robin Hood's bow was straighter...
2022-3-26
Labroides
Bashy Posted at 3-26 18:10
What's under that red line looks straight.
Can we be sure that the boundary of the black area is actually straight?
I'd be more concerned at how soft and mushy the video quality was before getting excited about this.
2022-3-26
Bashy
Labroides Posted at 3-26 18:45
You can just see the black appearing past that line, again the line is masking some of it, thats why when i move my line further up, it highlights the issue more,  ive just watched the video in the link a few posts up and wow, its very noticeable...
2022-3-26
Bashy
Heres the link in case ya missed it
2022-3-26
Labroides
Bashy Posted at 3-26 19:12
In the video, that building is only visible (and only in part of the frame) when the camera is panning across it.
Rolling shutter causes all kinds of distortion when things are moving.
I don't think this video is suitable for drawing any conclusions.
There are  better ways to tell if there really is an issue, and if the OP is concerned, he should try those before assuming that firmware updates caused a problem.
2022-3-26
DJI Stephen
Hello there Trzcina. Thank you for reaching out and for these information that you have given. I will forward this matter to the designated DJI department for further evaluation. Thank you.
2022-3-26
Trzcina
Poland
Labroides Posted at 3-26 19:48
Apparently, for DJI this video is suitable for raising a concern. Issue has been reported and DJI opened investigation process I have ticket for that. I will update this thread with results of process, I will repeat this flight with 4K mode enabled to see if there is any difference. For me, this happen after firmware upgrade, so I have no reason to believe that this is not the root cause. Stop your fanatism, face the facts, solve the problem.
2022-3-27
Mhinc
Trzcina Posted at 3-26 10:37
Wow!  I think you need to take a look in the mirror in regards to being rude.  You are also demanding.
First of all, you come on here, new user and immediately start going off about your issues, without reading other threads or searching for this same issue.
Secondly, you sound like you are expecting something way more for the cost you paid for your Mini 2.  I am sorry but you get what you pay for.  DJI has crammed a LOT into the Mini 2 with a cheaper price point.
Also it's amusing that you think @ing the mods will get you anywhere.
2022-3-27
Mhinc
Trzcina Posted at 3-27 01:27
Ha ha ha.  Ya they opened a ticket, let us know how that goes for you.  You are dreaming if you think that means anything when it comes to DJI support.  They'd open a ticket for anything, just to shut you up.  Others here will agree.  Trust me, they don't consider your issue and issue, they are just shutting you up.  They will either never get back to you, or tell you it's expected behaviour.
2022-3-27
Trzcina
Poland
Mhinc Posted at 3-27 01:41
1) Good point about myself not searching the threads. You are right here. Even worse point for DJI it has been noticed earlier and nothing was done about.
2) Very bad point for you justifying this issue with a price, and reason i think that is simple: it was simply not there with previous fw versions - I can prove it with evidence.  When you say such things in a such way, you allow dji not to take care anymore.
Now you are asking myself to look in the mirror: I started with facts - and true, with frustration  - and ended up with one or two fanatics making an idiot out of me in light of visible evidence. In course of discussion, the issue has been proved, I provided evidence which has been reviewed and confirmed, and as you have noticed similar thread was there one year ago. Despote of that some of users of this forum would not agree they were in the mistake, have kept their mindset everywhere but not close to agree, that is the issue there. In such case, I have limited patience.
2022-3-27
Trzcina
Poland
Mhinc Posted at 3-27 01:43
And if that is the case - and you may be right - then the myth of wonderful dji support wilk be gone. I am however not the one who surrenders just because "this is the way they do that to shut you up".
2022-3-27
12Next >
