roamer105
Flight distance : 3156145 ft
I am not sure if this problem is exclusive to the M3. I own an RC Pro and use it with an A2S. After the latest update which included the RC Pro I experienced the strangest disconnect (I NEVER had any such thing prior to this update). The A2S was at a roughly 45 degree angle above and to the side of me, very close at approximately 100' distance hovering. The location was far away from civilization so not likely signal pollution. Suddenly the RC Pro indicated total signal loss drone disconnected (it skipped weak signal etc). I waited and moved the remote a little, but nothing changed. The A2S continued hovering and was timing out the disconnect, after which it started the RTH process. In the interim I manually restarted the FLY app on the RC Pro. It reconnected immediately with full bars as before and everything was fine again. I flew a few more missions since and nothing like that occurred again.
I suspect it has to do with the latest version of the FLY app. |
